A Novelty Clock Makes The Best Tiny Mac Yet
We’re lucky enough in 2026 to have cheap single-board computers fast enough to emulate machines from the 1990s, touching on the 32-bit era. We’ve seen a few projects as a result, emulating the Apple Macs of the 68000 era, but even with the best 3D printing, they can disappoint when it comes to the case. So when [This Does Not Compute] saw a novelty alarm clock using a very well-modelled mini replica of an early Mac, putting a Mac emulator in it was the obvious way to go.
The project uses a Raspberry Pi with a small colour LCD.  The video below the break takes us through the process of gutting it and mounting the Pi and display on a custom 3D-printed bracket. In an unexpected touch, parts of the original LCD are used to give the curved corners, which owners of an original Mac will remember. It may have a little further to go in that its fake floppy drive is begging to be converted to an SD card slot, and it has a now-unused brightness dial. But we’d say it’s one of the best little Mac emulators we’ve seen so far, if perhaps not the smallest.
8 thoughts on “A Novelty Clock Makes The Best Tiny Mac Yet
  1. I’m no soldering expert but OP’s should learn to use some flux because their solder joint are awful. But the project is really nice!
    1. Good point. There’s “solder honey”, for example, based on colophony solved in alcohol.
      It’s a paste that I think is less aggressive than ordinary rosin or that industrial “fish paste” (the smelly solder flux).
Leave a Reply to E. RodommocCancel reply
