A Novelty Clock Makes The Best Tiny Mac Yet
We’re lucky enough in 2026 to have cheap single-board computers fast enough to emulate machines from the 1990s, touching on the 32-bit era. We’ve seen a few projects as a result, emulating the Apple Macs of the 68000 era, but even with the best 3D printing, they can disappoint when it comes to the case. So when [This Does Not Compute] saw a novelty alarm clock using a very well-modelled mini replica of an early Mac, putting a Mac emulator in it was the obvious way to go.
The project uses a Raspberry Pi with a small colour LCD.  The video below the break takes us through the process of gutting it and mounting the Pi and display on a custom 3D-printed bracket. In an unexpected touch, parts of the original LCD are used to give the curved corners, which owners of an original Mac will remember. It may have a little further to go in that its fake floppy drive is begging to be converted to an SD card slot, and it has a now-unused brightness dial. But we’d say it’s one of the best little Mac emulators we’ve seen so far, if perhaps not the smallest.
8 thoughts on “A Novelty Clock Makes The Best Tiny Mac Yet
    1. Good point. There’s “solder honey”, for example, based on colophony solved in alcohol.
      It’s a paste that I think is less aggressive than ordinary rosin or that industrial “fish paste” (the smelly solder flux).
Leave a Reply to werfweCancel reply
