Variable-Pitch Propellers For More Efficient Quadcopter
Quadcopters tend to have very poor efficency because of their high disk loading. High disk loading– that is, how much weight each square meter of area swept by the propellers must carry–is almost unavoidable with conventinal quadcopters, which are controlled by throttling the four props. Make the propellers too big, and their inertia slows down that control loop, leading to stability problems. [rctestflight] had an idea to solve this, by borrowing a technology from the world of fixed-wing aviation: variable-pitch propellers.
In aircraft use, they are not new, dating back to the end of the first world war. They’re made for everything from the largest turboprops to the  75 kW(100 HP) Rotax 912. By varying the propeller pitch, you can keep the engine turning in its ideal RPM range but still vary thrust by taking a larger or shallower ‘bite’ out of the air with each sweep of the prop. You can probably see how this applies to the quadcopter: a well-designed pitch-change mechanism is going to be much quicker than throttling a big prop with lots of rotational inertia. That’s the theory.
To test it, [rctestflight] builds some large 3D-printed variable pitch props, hooks them up to regular drone motors via a belt drive, before going on–you guessed it–an RC test flight. To make that work, he’s got the pitch servo being driven from what should be the flight controller’s thrust output to each motor. Aside from the vibrations from imperfect balance on the 3D-printed props, it flies quite well– and much better with pitch control than trying to vary the RPMs of those heavy props. He’s even able to reverse the propeller pitch, making this perhaps the first quadcopter capable of autorotation. Well, almost, given that it lost control and came apart when he cut the throttle.
As for efficiency, it is exactly what you’d expect from this disk loading– so, higher than a conventional quad–even with losses from the belt drive and the high-friction surface of a 3D print. Speaking of 3D-prints, the props did hold up to the maximum RPMs he could throw at them, so no ‘kaboom’ in this video. There is a fun rotary subwoofer bonus at the end, though.
Overall, [rctestflight] thinks his variable-pitch quadcopter proves the concept, but that if you’re going to all this effort you may as well build a helicopter and have fewer points of failure. We kind of have to agree. That is how it worked out historically, after all.
This isn’t the first time we’ve seen hackers trying to improve drone efficiency– there was the hybrid ‘giant propeller’ drone a while back, and the ‘slap a wing on it’ technique featured more recently.
6 thoughts on “Variable-Pitch Propellers For More Efficient Quadcopter
  1. “They’re made for everything from the largest turboprops to the 75 kW(100 HP) Rotax 912”
    I realize this is pedantic, but the Rotax 912 also comes in a 60 kW(80 HP) version, which presumably also works with variable pitch props.
    1. well while we are picking nits,
      Collective changes lift without altering RPM
      Variable pitch refers to adjusting propeller blade angles to optimize thrust and efficiency across different speeds
      The stingray 500 was a collective pitch quad and only had a 390w (0.52hp) motor.
  2. “…if you’re going to all this effort you may as well build a helicopter and have fewer points of failure. ”
    Have a look at the Boeing V-22 which has all the effort, all the maintenance problems and all the teething pains but can achieve much faster speeds than a conventional helicopter while maintaining VTOL/hover capability and will take things and people nearly anyplace more efficiently. Darn noisy though….
    What would be a lot more interesting from a hacking/geekery perspective would be to have cyclic controls on a duo- or tri- copter to make them as stable as a quad without any tail rotor.
    1. Would still suffer from vortex ring effects from rapid settling. If nearly coaxial, just a hard impact with terrain. If wide-spaced, tends to result in rolling inverted then power-diving.
      Also, the V-22 isn’t “more efficient” in general, and that noise is one of the consequences. Efficiency is not loud, since loudness is a consequence of wasted energy. It is more “convenient” (in many ways), but neither fuel consumption nor other common measurements of efficiency really qualify it as “more efficient”.
Leave a Reply to deLCancel reply
