Art of 3D printer in the middle of printing a Hackaday Jolly Wrencher logo
Giving Resin 3D Printers Another Shot After Six Years
My initial experience with a 3D printer came in 2020, when I got access to a buddy’s Creality LD-002R SLA printer. This was one of those awkward transition phases for SLA printers, where inefficient RGB LCDs finally got replaced by monochrome LCD panels, thus massively reducing the required exposure time and increasing the LCD panel’s lifespan.
The closely related Creality LD-002H is a monochrome SLA printer, but as this wasn’t the one that this friend opted for we had to learn the ropes on this more old-school printer. In terms of specifications this meant a build volume of 119 mm x 65 mm x 160 mm to play with and a claimed 26.1 µm resolution. Despite some struggles along the way, this machine churned out impressively high levels of detail with whatever cheap resin we threw at it, and even the post-printing processing became easy once we added a flex plate to the build plate and tweaked the cleaning and curing steps.
Despite all these positives, we both drifted away from resin printing, mostly due to the still messy and smelly printing process. FDM printers seemed like a better deal, especially after said buddy got his mittens on a used IDEX FDM printer. I would eventually go through a rather loathsome Creality Ender V2 experience before ending up with my current-day Elegoo Neptune 4, and resin printing seemed to be a thing of the past for me. Until recently, that is.
Continue reading “Giving Resin 3D Printers Another Shot After Six Years” →
Java Ring Restored After Nearly 30 Years
Back in the late 90s when absolutely everybody knew that Java was going to become the one programming language to rule them all, the Java Ring was handed out to folks at Java developer conferences as an example of how it was going to revolutionize smart wearable devices. Recently [Daisuke Yamazaki] got his mittens on one of these collector’s items to see about reviving it.
We talked about these rings and associated iButton devices before, with their intended use being primarily to act as authentication keys. For the Java Ring, this use was mostly just used as a kind of gag, whereby visitors to these conferences could specify their coffee preferences at a terminal, having this programmed into the ring so that they could get their desired cup of literal java at various bean juice dispensers around the conference site.
Talking to one of these iButton devices requires a so-called Blue Dot adapter, which [Yamazaki-san] purchased along with the ring. Although the device happily responded on the 1-wire bus, figuring out how to interact with the original Java-based firmware and answering the question of how much of the original information of someone’s coffee preferences in ’98 were retained would require more sleuthing.
Continue reading “Java Ring Restored After Nearly 30 Years” →
20 FPS On E-Paper Display Without Help
If electronic paper displays have one downside, it’s generally refresh rate. Earlier versions of the tech might only have been able to do single-digit frames per second, while modern, mid-range devices can sometimes manage 10-20 FPS — and that’s not including the frames needed to blank the display. Getting up past that double-digit barrier typically requires higher-end displays, more powerful processors or FPGAs, and more money. On the other hand, [Tony] was recently able to get 20 FPS out of an ESP32-based device without using any extra processing power.
The key to improving e-paper performance is understanding how the display actually works. The “ink” consists of microscopic charged pigment particles that physically move in response to electric fields, making the display much slower than LCD or OLED panels. Rather than fully erasing and redrawing every frame, the software takes advantage of the particles’ existing state by generating optimized driving waveforms that only move the particles needed to produce the next image. On the software side, an MPEG-like encoding is used so only changes between frames are transmitted and converted into these waveforms, reducing unnecessary data transfers and allowing much higher frame rates.
[Tony]’s method is able to drive 960×540 panels, like those found in the Lilygo or M5PaperS3, to 20 FPS, and these platforms are based on nothing more than the capable but limited ESP32 chip. It’s an impressive push, and worth checking out the video in the linked project page. We assume you’d need a little more to drive something like the massive e-paper display found in this home automation setup, though.
Continue reading “20 FPS On E-Paper Display Without Help” →
