Did you know emojis can be executables? Well, they are if you treat them like Intel 8088 or 8086 machine code, anyway. [GloriousCow] shared this clever revelation, demonstrating that executable programs could be created entirely from emojis. To really appreciate why, it’s necessary to take a small step back.
It all started when [GloriousCow] happened to notice, entirely by chance, that ๐ (the goat emoji) was F0 9F 90 90. Anyone familiar with x86 assembly language probably recognizes 90h as nop,ย or null operation, or “spend a cycle doing nothing”. What about F0 and 9F? Together they are lock lahf (assert the bus lock signal then copy some status flags into register AH) which, on an 8088 and 8086, essentially does nothing.
This means the goat emoji (F0 9F 90 90) is 100% technically valid machine code. It doesn’t do anything, but here’s where it gets even more interesting.
There are loads of emojis, and manyย of them start with F0 9F followed by two more bytes, and many of those other two-byte combinations are surely also valid machine code. Could one create a meaningful executable program consisting entirely of emojis? The answer is yes, and [GloriousCow] crafted a simple Hello World program to demonstrate.
The simple program looks like this: ๐ธโบ๏ธ๐ฐ๐โ๐๏ธ๐งฏ๐งฏ๐งฏ๐ฎ๐๐ฆฎ๐ชโ๐ฐ๐น๐๏ธ๐งฏ๐งฏ๐งฏ๐งฏ๐๐ช๐งฏ๐๐งฎ๐ซช๐๐งฎ๐๐ฎ๐ช๐โญ. Save that string of emojis to a file, give it a .com extension, and run it in DOSBox with CPU type set to 8086. It’ll printย HELLO at the bottom-right of the screen by writing directly to video memory.
There are loads more details on the original blog post, including plenty of resources and tips for writing your own executables with emojis. There’s also a much more involved VGA demo program made from emojis, so give it a look.
Some of you may be aware that ASCII characters can also be used in a similar way (and more flexibly, since they are not four-byte combinations like emojis). This was used in BASIC programs as a way to cleverly embed machine code in things like REM statements, creating odd-looking code that did things in BASIC that shouldn’t have been possible.
I’m old enough to remember when you could make C64 output “Microsoft sux” by using correct sequence of POKEs. Those days are never coming back.
Vachement!
It’s rather meta in a way; github ๐งฏ๐ฎ๐๐ฆฎ๐ช markdown file ๐ชฑ’s, code written in “๐๐ฉ”.
(comment system makes me sad)
Few more logical steps and Piet (programming lang) enters the chat.
I guess I’ll grab a bucket of popcorn and wait for the first emoji-based malware exploit delivered by Outlook or Chrome. Any bets?
