A Modern Smalltalk
In the history of object-oriented (OO) computer languages, Smalltalk has a special place. It wasn’t the first OO language, and it hasn’t spread as well as some others. But it was the first OO language many people encountered, and it influenced many other languages you’ve probably seen. Developed at the famed Xerox PARC, it also introduced many people to the “model/view/controller” (MVC) architecture. Cuis Smalltalk is a free and portable modern Smalltalk-80 environment. It replaces the traditional MVC framework with Morphic, but otherwise, it would be very familiar to someone who used Smalltalk in the 1990s. The project’s goal is to stay simple at the core, although you can add complexity via packages.
The software has been around for a while, but it is on a rolling release model, so the install page suggests you clone the Git repo. You can, however, get a stable release, which might be important if you were deploying applications. Running the program results in a Cuis desktop where you can open various things like workspaces, help documents, and the transcript.
Smalltalk throws some people because it takes OO to an extreme. For example, you don’t add two and three using an operator. You send the object two a message that includes another object, three. You can think of sending a message as calling a method on an object. As with virtual functions in C++, different objects can respond differently to the same request. For example, an Animal class might have a speak message that causes a cow to print “moo” and a chicken to print “cluck.”
You get used to it, and there’s a very nice class browser that lets you examine classes and what you can do with them. There are even packages to work with an Arduino over a serial port. They haven’t been updated lately, so they might (or might not) need a little work.
We’ve looked at GNU Smalltalk before. We’ve also seen a version that runs directly on a Raspberry Pi.
9 thoughts on “A Modern Smalltalk”
    1. In theory, yes-ish (with 1MB RAM via some complex bank switching). In reality Smalltalk is rather bulky (from a 80’s point of view) and I don’t see away of running effectively on a 6502 chip.
    2. Digital Smalltalk/V ran on a 4.77 MHz 8088 PC with 768k. But the PC was limited to 640k… So every now and then while it was running, it would burp (literally play a sound effect), write out some of RAM to disk, and read something else in.
      1. And it ran acceptably, a usable product.
        It is inside some HP products made in Coloraro Springs.
        Tektronix had their own Smalltalk, used in workstations and buried inside some scopes.
        Hardware engineers picked up OOP much faster than softies, and ran with jt.
  1. Apple’s Smalltalk on a fat mac is glacially slow. It predates L Peter Deutsch’s seminal JIT interpreter.
    Nonetheless it was sufficient in 1986 to convince me that OOP was the way forward, unlike Prolog or LISP.
