[Jan] was looking for a way to monitor web site hits while sitting on the couch. This lead to the Lucky Cat Hit Counter. The hack gives a stock Lucky Cat some new hardware: a servo, a RGB led, a light sensor, and a 7 segment display. The added components are controlled by an Arduino Ethernet.
The Arduino Ethernet is set up as a web server. When a visitor fetches [Jan]’s site, a GIF is requested from the Arduino. This trigger changes the RGB LED color, increments the seven segment display, and of course, makes the cat wave by actuating the servo. The light sensor is used to make the cat silent at night. When the light value is below a threshold, night mode is engaged and the cat doesn’t wave.
After the break is a video walk through of the Lucky Cat receiving some HTTP requests.
