Control the heat with a PID
Cozy Heat Control With An Arduino
[George Dewar] and his wife live in a typical 1940’s house in New Zealand , which in case you didn’t know, have a little insulation in the ceiling… and nowhere else. Like most, they put up with the cold — but after having a baby, [George] decided it was time to start controlling the heat a bit better.
They have an electric oil radiator which works well, but isn’t very smart. It only has 6 settings — not very useful when you’re trying to stay at a certain temperature. First off, they looked into a plug-in thermostat controller, and found a cheap one called the HeaterMate. Unfortunately it left a lot to be desired. For example, it didn’t seem to have PID control at all — and for an oil radiator, when you turn it off… it’s still going to heat the room for a while. He also found that because of the high current load of a heater … the device would read a few degrees over room temperature when operating. Unperturbed, [George] took this opportunity to design and build his own PID thermostat controller instead.  Continue reading “Cozy Heat Control With An Arduino” →
