Modded Server PSU Provides Plenty Of Current
Most makers find themselves in need of a benchtop power supply at some point or another. Basic models can be had relatively cheaply, but as your current demands go higher, so does the price. [Danilo Larizza] has figured out an alternative solution—repurposing old server hardware to do the job instead.
The build is based around an HP Common Slot (CS) server power supply. They can be readily had for well under $50 if you know where to look. Even better, they can deliver over 50 amps at 12 volts, which happens to be a very useful voltage indeed. All you need to do is some minor mods.
A jumper on a couple of pins will get the power supply running, and with the addition of some terminals for your hook-up leads, you’re ready to go. As a hot-swappable single unit, the power supply is already outfitted with a ventilation fan to keep everything cool. If so desired, you can even make some further mods to bump output voltage a little ways past 13 or 14 volts if you’d like to use them for certain battery charging tasks.
Sure, you’re not getting a variable power supply, but if you need 12 volts and lots of it, this is a great way to go. We’ve featured similar builds before, too, turning ATX PC power supplies into useful benchtop tools.
Continue reading “Modded Server PSU Provides Plenty Of Current”
