Testing 7 Wago-like Wire Connectors For Science And Fire
At the intersection of saving a few bucks and expensive home insurance claims due to a house fire, we find clones of certified and tested electrical connectors, even when many would argue that so-called wire nuts are fire hazards no matter how many certification labels are on them. When it comes to no-fuss wire connectors, Wago clamp connectors are an attractive target to save some money on due to their perceived high cost. But how expensive are they really?
This was the thought behind a recent video by [GreatScott!] (also embedded after the break) when he hopped onto everyone’s favorite e-commerce website and searched for ‘clamp lever terminal’. The resulting selection of seven connectors come in a wide variety of shapes, colors and configurations, though all are supposedly rated for mains (250 VAC) voltage and safe enough to put into a permanent installation.
While running the connectors through their paces with high-current, fire and mechanical strength tests, the conclusion was that all are good enough for hobbyists use and some brief connections while testing, but that only the ones with independent certification marks (like VDE) filled him with enough confidence to consider using in house wiring. One of these being the connectors by the German brand ViD, which would seem to be a slightly cheaper alternative to the Wago connectors, with similar guarantees of safety.
At the end of the day it is the certification that matters, after all, since long-term reliability is of primary concern with house wiring, not whether a few Euros were saved on material costs.
Continue reading “Testing 7 Wago-like Wire Connectors For Science And Fire” →
