At the 33rd annual Chaos Communications Congress, [Antonio Barresi] and [Erik Bosman] presented not one, not two, but three (3!!) great hacks that were all based on exploiting memory de-duplication in virtual machines. If you’re interested in security, you should definitely watch the talk, embedded below. And grab the slides too. (PDF)
Memory de-duplication is the forbidden fruit for large VM setups — obviously dangerous but so tempting. Imagine that you’re hosting VMs and you notice that many of the machines have the same things in memory at the same time. Maybe we’re all watching the same cat videos. They can save on global memory across the machines by simply storing one copy of the cat video and pointing to the shared memory block from each of the machines that uses it. Notionally separate machines are sharing memory. What could go wrong?
Continue reading “33C3: Memory Deduplication, The Hacker’s Friend”
