Need a high definition projector? Don’t have a thousand bucks sitting around? Then this hack is for you! [TheJinxster] threw together this awesome HD projector, and it cost him absolutely nothing to build!
He started by picking up an old overhead projector off of Freecycle. Freecycle is a great grassroots network, kind of like Kijiji or Craigslist — but everything is free. It’s all about reuse and keeping useful things out of the landfills. Anyway, he also had an old LCD monitor sitting around gathering dust…
Putting two and two together he took apart the LCD, laid the bare screen on top of the glass and, well, that’s it! It’s seriously that simple. The hardest part was taking apart the monitor — the overhead projector and mounted lens took care of the rest. The beauty with a system like this is you can get high definition out of a relatively small and cheap LCD panel! The only thing is it won’t last forever — LCDs (especially monitor LCDs) aren’t designed to pass through that much light.
Don’t believe us? Check out the following video.
Continue reading “Make An HD Projector For Next To Nothing!”
