Spring is on the way for our friends down under. With that in mind [x2Jiggy] built this compact fluorescent grow lamp to help start the seeds for his garden. He used materials that are easy to find, and multiple bulbs means that you can mix and match their color warmth in order to get the wavelengths of light best for plant growth.
He started by building the box out of MDF. It is lined mostly with a reflector meant to go in your car’s windshield when you leave it in a hot parking lot. He sealed the seams of the reflector using what he calls flashing tape. This is the rubbery type of stuff used as soft flashing around windows.
The bulb sockets came from an old string of party lights. Wiring is run through plastic junction boxes which keeps the setup code-compliant. Each of the CFLs draw 20 Watts for a total consumption of 160 Watts. Combine this with a DIY hydroponic tent and you’ll be eating fresh greens year round.
