We’ve known people to put down a small ice rink in their back yard during the winter. But a machine to resurface these diy rinks is unheard of until now. The big name in rink resurfacing is Zamboni, the person who invented this method of keeping the ice pristine.
This has almost everything you would find on a commercial model. The tires are studded with stainless steel screws for traction. The riding lawnmower has had its grass cutting blades replaced with a single steel blade that skims the surface of the ice. There’s even a tank of water which is distributed by a copper pipe with many holes and a squeegee which drags behind the machine. The only thing this is missing is a collection system for the slush which is generated by that skimmer blade. But as you can see in the clip after the break, it does just fine without it.
Continue reading “Backyard Zamboni Keeps The Best Diy Ice Rink In Town”
