[anfractuosus] has been reading magnetic stripe card… optically!
While hackers routinely read and write stripe cards, this is the first time we’ve reported on optically imaging and decoding data from the magnetic stripe. [anfratuosus] used a magnetic developer which is designed to allow visual inspection of the magnetic stripe. The developer uses micron sized iron particles in a suspension which are dropped onto the stripe. To the particles, the magnetic stripe looks like a series of magnets lined up. Long magnets
represent 0s and short magnets 1s. With each bit the orientation of the magnet changes, something like the diagram to the right. The magnetic field is strongest where the poles meet. So the iron particles are attracted to these flux reversal points on the stripe creating a visible pattern . There’s an awesome video of the process in action below.
While magnetic developer was designed for debugging faulty recording systems [anfratuosus] went a step further scanning the “developed” card, and writing a tool to decode the images and extract the card data. [anfratuosus] doesn’t mention any particular application, we love this circuitous hack anyway!
Continue reading “Hacker Reads Magnetic Stripe Card With Flatbed Scanner”
