Clocks come in many styles and sizes, with perhaps the most visually pleasing ones involving marbles. Watching these little spheres obey gravity and form clearly readable numbers on a clock has strong mesmerizing qualities. If you’re not into really big marble clocks, or cannot quite find the space for a desk-sized clock, then the tiny marble clock by [Jens] may be an option.
While he totally loved the massive marble clock that [Ivan Miranda] built, it is a massive contraption that’s hard to justify as a permanent installation. His take on the concept thus makes it as small as possible, by using a pick-and-place style arm to place the marbles instead. Although the marbles don’t do a lot of rolling this way, it’s decidedly more quiet, and replace the rumbling and click-clacking of marbles with the smooth motion of a robotic arm.
Another benefit of this clock is that it’s cheap to make, with a price tag of less than $23. A big part of this is the use of cheap SG90 micro servos, and a permanent magnet along with a mechanism that pushes the marble off said magnet. Perhaps the biggest issue with this clock is that the arm somewhat obscures the time while it’s moving around, but it’s definitely another interesting addition to the gallery of marble clocks.
We have previously seen such clocks built out of wood and brass as well as 3D-printed using pendulum mechanisms, which can be made pretty compact as well, albeit with a more analog vibe.
Thanks to [Hari] for the tip.
Continue reading “The World’s Smallest Marble Clock With Pick And Place Arm”
