After receiving a vaccination shot, it’s likely that we’ll feel some side-effects. These can range from merely a sore arm to swollen lymph nodes and even a fever. Which side-effects to expect depend on the exact vaccine, with each type and variant coming with its own list of common side-effects. Each person’s immune system will also react differently, which makes it hard to say exactly what one can expect after receiving the vaccination.
What we can do is look closer at the underlying mechanisms that cause these side-effects, to try and understand why they occur and how to best deal with them. Most relevant here for the initial response is the body’s innate immune system, with dendritic cells generally being among the first to come into contact with the vaccine and to present the antigen to the body’s adaptive immune system.
Key to the redness, swelling, and fever are substances produced by the body which include various cytokines as well as prostaglandin, producing the symptoms seen with inflammation and injury.
Continue reading “Mechanisms Behind Vaccine Side-Effects: The Science That Causes That Sore Arm”
