A small mood/busy indicator attached to a laptop.
Personal Traffic Light Stops Them In Their Tracks
Working from home can be pretty cool, but if you’re not the only one in the house trying to do it, the whole situation can feel like you’re right back in the office with all those walking, talking distractions. Except they’re in pajamas instead of business casual.
The parts needed to build this mood indicator.So, what’s the answer? Many times it’s not practical to stop what you’re doing, especially just to communicate that you’re busy. We suppose you could glare at them, put up your hand, or even give a dismissive wave, but a better solution might be this mood signal built by [gokux].
Through a simple web app, you can be red to indicate that you’re super busy, yellow to mean busy-ish, and green for let’s gossip about the cats.
This mood indicator is built on the Seeed Xiao ESP32-C3 and shows the given mood indicator on a small matrix of sixteen WS2812B LEDs. It’s powered by a 600 mAh, 3.7 V battery and a small push button switch. As usual, [gokux] has grade-A instructions for building your own version of this slick solution.
Would you like something more tactile and low-tech? Check out our own [Bob Baddeley]’s free/busy indicator from the lockdown days.
Internet-Connected Box Displays Emotion, Basement Dwellers Still Unaffected
For one reason or another, Twitter has become the modern zeitgeist, chronicling the latest fashions, news, gossip, and irrelevant content that sends us spiraling towards an inevitable existential ennui. This is a Twitter mood light. It tells you what everyone else on the planet is feeling. You, of course, feel nothing. Because of the ennui.
[Connor] decided it would be a good idea to audit the world’s collective mood using experimental social analytics. He’s doing that by watching millions of tweets a day and checking them against hundreds of keywords for several emotions. These emotions are graphed in real time, placed on a server, correlated and corroborated, and downloaded by a moodLight. Inside the moodLight, the emotions are translated into colors, and displayed with the help of a few RGB LEDs.
The moodLight is currently a Kickstarter campaign, with a $30 pledge getting you an assembled board with an ATMega328, an ESP8266, a few RGB LEDs, and a laser cut enclosure. After it’s assembled, the moodLight connects automagically to the analytics server for a real-time display of the emotional state of the Twitterverse. The display is updated every second, making the backend of this build just slightly more impressive than Kickstarter itself. It’s great work from [Connor], and an interesting experiment in analyzing the state of the Internet.
