According to [Dr. Tom Lehrer’s] song Pollution, “Wear a gas mask and a veil. Then you can breathe, long as you don’t inhale!” While the air quality in most of the world hasn’t gotten that bad, there is a lot of concern about long-term exposure to particulates in the air causing health problems. [Ashish Choudhary] married an Arduino with a display and a pollution sensor to give readings of the PM2.5 and PM10 levels in the air.
The sensor uses a laser diode and a photodiode to detect and count particles, while a fan moves air through the system. If you aren’t up on pollution metrics, PM2.5 is a count of very fine particles (under 2.5 microns) and PM10 is a count of particles for 10 microns. You can find a datasheet for the device online.
Continue reading “Ooohhh, That Smell: Arduino Monitors Air Quality”
