Many hackers have familiar sayings in their heads, such as “If it ain’t broke, don’t fix it” and KISS (Keep it simple, stupid). Those of us who have been in the field for some time have habits that are hard to break. When it comes to personal networks, simplicity is key, and the idea of transitioning from IPv4 to IPv6 addresses seems crazy. However, with the increasing number of ‘smart’ devices, streaming media gadgets, and personal phones, finding IPv4 space for our IoT experiments is becoming difficult. Is it time to consider embracing IPv6?
The linked GitHub Gist by [timothyham] summarizes the essential concepts for home network admins to understand before making changes. The first major point is that IPv6 has a vastly larger address space than IPv4, eliminating the need to find spare IPv4 addresses. IPv6 assigns multiple addresses to the same interface. The 128-bit addresses are split into a 64-bit prefix assigned by your ISP and a 64-bit interface identifier. Using SLAAC (Stateless Address Autoconfiguration), clients can manage their own addresses. You don’t have to use SLAAC, but it will make life easier. The suffix typically remains static, allowing integration with a local DNS server.
