File this one under: “Wow, that’s even possible?” xbox-scene hacker [RDC] has been hard at work converting his Xbox 360 to slot loading. To start, He removed the slot loading drive from a blueberry iMac G3. The loading mechanism is the top half of the drive. He split this off and married it to the reading mechanism in the Xbox’s Hitachi drive. The difficult part came with getting the drive to properly signal when it had a disc. He put together a custom circuit to do the detection and has a thorough description of how he solved the problem.
[Thanks, bic]
