Coke Can Fueled Power Generator
[Experimental Fun] shows us how you can create a cola power generator that runs on nothing more than cans of cola including the container and a little bit of sodium hydroxide to speed the reaction up.
This might sound a bit crazy, but it seems you can power an engine on little more than your favorite fizzy drink and the cut-up remains of an aluminum can. What happens is that aluminum and water create a chemical reaction when mixed together, which gives off hydrogen. Normally this reaction is very slow and would take years to make any noticeable marking on the aluminum, but with a little help from sodium hydroxide the reaction is sped up to such a rate that hydrogen is produced quite quickly.
The crazy contraption they created has a reaction chamber which then feeds the hydrogen through condenser then to a bubble filter made from a bottle filled with water. After that it is on through a carbon filter to get rid of any impurities, and finally it is fed directly into a two-stroke engine’s fuel line. Then engine still needs an electric start from a battery, but after that it runs directly on the hydrogen created during the reaction from the chamber.
This is quite a cool project, however you could replace the fizzy drink with water and still get the desired effect. Since the drink comes with the aluminum cans it seems like quite a good fuel though. There are other crazy fuels out the for the avid DIY hacker, but just be careful and don’t blow yourself up.
Continue reading “Coke Can Fueled Power Generator” →
