We’re used to those high voltage projects which use a self-oscillating transformer circuit with a TV flyback winding, and we have even at times railed against them for their inefficiency compared to a real flyback circuit using the same parts. But what happens if the same idea is used to create a low voltage instead of a high one? [D. Creative] has a soldering gun project doing just this, making a low voltage at a very high current.
The video of the project is below the break, and while electrically it’s nothing unexpected, we’re taken by the quality of the build. All the parts come from scrap electronics, the main transformer is three ferrite cores with a piece of copper busbar as the secondary. The circuitry is built dead bug style, and it’s housed in a gun-style case made by hand from sheet Perspex. It takes 12 volt power from a laptop power supply, and feeds it to the oscillator which is perched up at the back of the device. The transformer fits in the “barrel”, and a pair of large capacitors fit in the handle. We expect it to get hot, but the duty cycle on these devices in use is probably low enough to keep it from melting.
We like anything that uses scrap parts to make something useful, and we’re particularly taken with the casing of this one. It looks as though the parts come from old switch mode power supplies, something we’ve been known to rob ourselves.
