We’ve been watching the progress of the Space Cube since 2004, but PC Pro managed to get their hands on it first. Developed by the Shimafuji Corporation, it comes with 16 megabytes of flash memory and a version of Red Hat is run off a 1 gigabyte CompactFlash card. The design of the Space Cube is pretty minimal, but it’s got the basics down, from a USB port to a VGA output and a D-SUB RS232 input, and even an Ethernet port. The most interesting thing about it is the Space Wire port, which is a proprietary interface use by NASA, the ESA, and JAXA for outer space. Unfortunately for working hackers, this ingenious micro-computer will set you back about £1,500.
[via NOTCOT]
