Bootstrapped Tools, Live Stopped Motion, And A Dekatron Computer
Dallas Texas played host to an epic Hackaday meetup last weekend. The Dallas Makerspace was kind enough to open their doors, and we sure used them. Attendance was over capacity, with a line all night to screen-print your own T-shirt, a set of lightning talks that lasted nearly two hours, and plenty of hardware show-and-tell.
We’ll start off with three of the most impressive builds displayed. First is a set of simple designs that can be used to make tools in parts of the world where even a hammer is a luxury. Then it’s on to a clever entertainment device that uses discrete stopped-motion figurines to make live animations. We’ll take a look at the Witch-E project which is building a replica of the famous Dekatron-based computer. And finish up with the surprise hit of the meetup.
Continue reading “Bootstrapped Tools, Live Stopped Motion, And A Dekatron Computer” →
Light Painting – Still Shots And Animations
[Kim Pimmel’s] been doing some really interesting light painting with an Arduino. In the past we’ve seen several light painting projects which use long exposures to capture moving LEDs, or moving LCD displays. But [Kim’s] stepping it up a notch, using cold cathode flourescent lamps, electroluminescent (EL) wire, and lasers. The vibrant colors put out by these sources make for some great photos, but that’s not all she’s got up her sleeve. After accumulating a ton of still photographs from various shoots she decided to edit them together into stopped motion videos.
After the break you can see that one method she used to make these images was to spin the light sources on a standard audio turntable. An Arduino is controlled through processing via Bluetooth in order to move the stepper motor-mounted lights while the record player spins. Add some futuristic music thanks to Daft Punk (which is exactly what she did) and you’re in business.
Continue reading “Light Painting – Still Shots And Animations” →
