If you are like most people, your drone flights start on the ground and end either on the ground or–in more cases than most of us want to admit–in a tree. Earlier this year, DARPA awarded initial contracts for the Gremlins program. The idea is to produce unmanned aircraft that can launch from another aircraft and then later have another aircraft recover it.
The idea is to allow a plane to launch an unmanned sensor, for example, while out of range of enemy fire. Later another aircraft can retrieve the drone where a ground crew would get it ready for another flight within 24 hours. An aircraft facing missile fire could unleash a swarm of drones, confusing attackers. The drones have a limited life of about twenty flights, allowing for inexpensive airframes that use existing technology. You can see a concept video from DARPA about how air-launched drones might play a role in future air combat below.
