Vacuum dust bags are annoying. They’re expensive, one time use, and if you have an older vacuum cleaner, good luck finding replacements! [Karl] got fed up so he decided to make his own reusable dirt bag instead.
He’s using an old t-shirt as the new bag material but notes that you can use any other sufficiently drafty material as well — as long as it stops the dust but lets air through, you’re good! To seal the bag he’s using a piece of rubbery vinyl with a hole cut in it to seal against the intake pipe. This is sewn to the t-shirt with a piece of cardboard sandwiching the fabric. From there it’s just a matter of adding a zipper or Velcro, and you’re done!
He’s been using this filter for over a year and hasn’t had any problems with it yet — you can even wash it! While you’re at it, why not make a wet-spill attachment for your vacuum cleaner too?
