Simple, elegant, and well executed. This solenoid engine build is everything we’ve come to love about [Matthias Wandel]’s work. If you don’t recognize his name you probably remember the name of his site: Wood Gears.
In what feels like an afternoon project he put together a solenoid engine. It translates the linear motion of a small solenoid into the circular motion of a flywheel. The only specialized part in this hack is the solenoid. It has a pretty long throw and includes a hinge pin at the end.
The rest is crafted mostly of wood — it is admirable how he uses that table saw like a surgeon uses a scalpel. The wooden components include a base, flywheel, very interesting bearing blocks, and a few mounting brackets to hold everything in just the right place. Add to this a coat hanger for the cam shaft, the internals of a terminal strip for the cam, some heavy gauge wire, and you’re in business. The latter two make up a clever electrical switch that synchronizes the drive of the solenoid with the flywheel.
It’s amusing to hear [Matthias] mention that this engine isn’t very practical. We still think the project has merit — it’s great for learning about how simple an engine can be, and for developing an intuitive appreciation for how great commercially available motors and engines actually are. Plus, if you can mimic these fabrication techniques you can build anything. Great work on this one [Matthias], another thing of beauty!
Check out his video below, then go back and check out his air-powered engine and of course, a hack that actually uses wood gears.
