Portable Workbench Is Solid And Space Saving
Last week we covered the topic of electronic work benches. But we know that there’s more to life than soldering irons and tiny components. Sometimes to pull off a hack, you need to get your hands dirty, and get some sawdust in your hair. If you’re limited on space, or need to be able to move to different locations quickly, this shop workbench may just be what you’re looking for.
First, let us preface that this project is not open source. Now before you “boo!” too loudly, the designer [Ron Paulk] only charges $10 for the plans. We think that is a small price to pay for how much though has gone into the design. But hey, if you’re a bit crafty, we bet you could easily reverse engineer the build just from the pictures alone. Personally, we think there are times when it’s a good thing to support a project like this.
The basic design allows the workbench to be very rigid, but light weight. And if you don’t have room for it to be permanently set up, it tears down and stores away nicely. It seems like the plans are well done, but if you need a bit more guidance, there is also a 15 part video series that will guide you along the way (here is the youtube playlist.) Also, there is an overview video after the break.  So what are you waiting for?  Go out and make something!
Continue reading “Portable Workbench Is Solid And Space Saving” →
Putting A Workshop On Your Bike Rack
As a member of the Repair Cafe in Maastricht, [Bertoa] sometimes needs to take a few tools out into the field to repair mechanical and electronic devices. His previous solution to the problem was a toolbox in the trunk of his car, but he knew he could come up with a more environmentally friendly solution. He created a portable workbench that fits right on his bike rack that is able to transport all the tools needed for light repairs using only a bike.
[Bertoa]’s portable workbench is made up of two parts; each side has one small slide drawer perfect for storing screwdrivers and wrenches, as well as a second tilting drawer able to hold heavier items such as an electric drill.
The work surface joins the two sides of the workbench together and is able to fold out with the help of a piano hinge and a few brackets. The workbench is removable from the bike rack and is able to stand on its own (stowable) legs made of aluminum tubes.
Even though the portable workbench only weighs about 10kg, it’s able to support [Bertoa]’s full body weight; a wonderful addition to any maker’s bicycle and a great solution to working on projects in the field.
Updating Your Workspace For More Organized And Efficient Hacking
workspace-upgrade
If you’ve ever looked at one of [Todd Harrison’s] teardown or how-to videos closely, you would likely notice that his work bench looks like a standard hacker workspace. While we all try to keep our work areas clear of clutter, it’s not uncommon for components to pile up, cords to tangle, and things to get messy. [Todd] decided it was time to get a bit more organized, so he recorded a video showing how he went about the process.
Part of [Todd’s] work revolved around adding shelves to his bench so that he didn’t have measurement equipment stacked on top of one another. He also spent a good amount of time adding 30 additional plug sockets to his work space, replacing the single socket he had been struggling with for years.
Obviously this is not really a hack in and of itself, though this sort of reorganization is an important to efficient hacking all the same. We like the fact that [Todd] took the time to explain his process and materials in great detail – it will no doubt be helpful to those new to hacking.
Continue reading to see [Todd’s] video in its entirety, or swing by his blog for more pictures and details.
Continue reading “Updating Your Workspace For More Organized And Efficient Hacking” →
