This Week In Security: Docker Auth, Windows Tools, And A Very Full Patch Tuesday
CVE-2026-34040 lets attackers bypass some Docker authentication plugins by allowing an empty request body. Present since 2024, this bug was caused by a previous fix to the auth workflow. In the 2024 bug, the authentication system could be tricked into passing a zero-length request to the authentication handler. In the modern vulnerability, the system can be tricked into removing a too-large authentication request and passing a zero-length request to the authentication handler.
In both cases, the authentication system may not properly handle the malformed request and allow creation of docker images with access to stored credentials and secrets.
Bugs like these are increasing in visibility because AI agents running in Docker, like OpenClaw, may be tricked via prompt injection into leveraging the vulnerability.
Windows CPU Tools Compromised
videocardz.com notes that the popular Windows monitoring software Cpu-Z and HWMonitor appear to have been compromised. Reports indicate that the download site was compromised, not the actual packages, but that it was redirecting update requests to packages including malware. While the site has been repaired, unfortunately it looks like there is no warning to users that the downloads were compromised for a period of time.
Anecdotally, there has been a rash of Discord account takeovers in the past week, where long-standing accounts in multiple servers have been compromised and turned into spambots. While there is no evidence these events are linked, clearly a new credential or authentication stealing malware is in play, which involves stealing credentials from Discord.
X.Org and XWayland Updated
The X.Org and XWayland servers saw security updates this week, fixing a handful of vulnerabilities involving uninitialized memory use, use-after-free, and reading beyond the end of a buffer.
The vulnerabilities are generally classified as “moderate”, but of course, don’t leave known vulnerabilities when you can avoid it! Fixed releases should find their way into distributions soon.
Continue reading “This Week In Security: Docker Auth, Windows Tools, And A Very Full Patch Tuesday” →
