Fixing A GameCube’s Dodgy Optical Drive With Fresh Capacitors
Generally when a game console with an optical drive stops reading discs the first thing that people do is crank on the potentiometer that controls the power to the laser diode to ramp up its output. While this can be a necessary solution to eke out a bit more life out of a clearly dying laser diode, this can actually massively shorten the lifespan of a good diode that’s just held back by bad capacitors. This is demonstrated by [Skawo] with a fix on a GameCube that stopped reading discs.
While it’s absolutely true that laser diodes have a limited lifespan, so do the capacitors and other components in the system. Thus, after tearing down this Japanese GameCube, [Skawo] accesses the optical PCB for some delicate plier-based capacitor surgery. One can absolutely question such violence, as well as the replacement mix of MLCC ceramics and a stray THT electrolytic capacitor, but the results after reassembly are obvious.
Without having to adjust the laser diode’s potentiometer, the game console now happily reads the game disc while the laser diode breathes a sigh of relief. Although all GameCube consoles will face the inevitable demise of their optical drives – barring a replacement optical pickup solution appearing – with this capacitor replacement solution it’s at least possible to stave off that undesirable time for a bit longer.
Continue reading “Fixing A GameCube’s Dodgy Optical Drive With Fresh Capacitors” →
FRED Comes To Hobby Operating Systems (and Linux)
Those who have worked on a hobby operating system for x86 will have interacted with its rather complex and confusing interrupt model. [Evalyn] shows us why and how to use Flexible Return and Event Delivery (FRED), a new standard by the x86 Ecosystem Advisory Group.
Of course, it would be silly to omit the fact that Linux received patches first. But that isn’t the interesting part; after all, Linux is often the first place to have support for this kind of thing. No, what’s interesting is [Evalyn]’s implementation, to our knowledge among — if not the first — non-Linux operating system to support it.
Part of the startup log of EvalynOS
The kernel confirming that FRED has been detected and enabled
To know why we should switch to FRED, we must first understand what it replaces. The Interrupt Descriptor Table (IDT) tells the CPU what code to run when certain interrupts or faults happen. The big problem that the IDT has is inconsistency, most egregiously the fact that the stack layout depends on which interrupt happened. To solve the issues with the IDT, FRED was created.
[Evalyn] shows us the process, starting at the documentation, then finding an emulator capable of it and culminating in a demo where DOOM runs in EvalynOS with FRED enabled.
Pentium II die shot. Martijn Boer, Public domain.
Making A Bronze Mirror From Scratch
Although modern-day silvered glass mirrors have pretty much destroyed the market for bronze mirrors, these highly polished pieces of metal once were the pinnacle of mirror technology. Due to the laborious process required these mirrors saw use essentially only by the affluent. That said, how hard would it be to make a bronze mirror today with all of the modern technologies that even a hobbyist can acquire for their shed? Cue [Lundgren Bronze Studios] giving it a shot, starting by casting something flat-ish to start polishing.
Just getting that initial shape to start polishing is a chore, with hammering out the shape possibly being also a viable method. When casting metal it’s tricky to avoid having air bubbles and other defects forming, though using a sand mold seems to help a lot.
After you have the rough shape, polishing using power tools seems like cheating, but as you can see in the video even going from 50 to 8000 grit with a rotating disc left countless scratches. Amusingly, hand sanding did a much better job of removing the worst scratches, following which a polishing compound helped to bring out that literal mirror finish.
A quick glance at the Wikipedia entry for bronze mirrors shows that a tin-bronze alloy like speculum metal was used for thousands of years as it was much easier to polish to a good mirror finish. The metallurgy of what may seem like just a vanity item clearly goes deeper than just polishing up a metal surface.
Continue reading “Making A Bronze Mirror From Scratch” →
Cooking With Plasma (Not Fire)
Cooking food with fire is arguably the technology that propelled humans to become the dominant species on Earth. It’s pretty straightforward to achieve, just requiring a fuel source, a supply of oxygen from the air, and a way to initiate the reaction; then it self-sustains. You wouldn’t think there’s much to improve, but what about cooking with plasma? [Jay] from the plasma channel is no stranger here, and he thinks that there may be something in this idea, certainly enough to actually build something.
Now, let’s be straight with you, this isn’t a new concept, and you can buy a plasma-based cooking appliance right now. But they are all AC-powered devices. What if you want to go camping? [Jay] attempts (and succeeds) in building a portable, rechargeable 600W plasma cooking device that can actually cook food, but it was not all plain sailing.
The existing off-the-shelf ZVS driver modules available were a bit weak and unreliable, and the required flyback coils were hard to find with the right specs, so he needed to get down to work building custom parts. First off, the coils. Custom formers were resin-printed and machine-wound with 4000 turns of fine wire, and then resin-sealed into the former. [Jay] takes care to explain that it is crucial to get all the air out of the windings, or else local flashover breakdown will occur and wreck the coil in a short time. We reckon the resulting coils look amazing in their own right!
Continue reading “Cooking With Plasma (Not Fire)” →
SolMate Charger
2026 Green Powered Challenge: SolMate Charges On The Move
We’ve all had those times when your electrical device of choice is running low on battery. Sometimes you even plan ahead and are also carrying a battery pack, but what happens when you’ve forgotten to charge the battery pack? This is the problem that [Arnov Sharma] addressed with the SolMate, a portable solar panel that keeps a battery bank topped up.
The SolMate is built around an efficient 2 W photovoltaic panel that’s not much bigger than a cellphone. This panel can supply 5 V at 400 mA on a sunny day. The solar output is more than enough to keep the internal 2000 mAh battery topped up and ready for use. Charging the Li-ion battery is handled by an IP5306 power management chip, which pulls double duty: it safely regulates charging while boosting the battery’s 3.7 V to the 5 V expected at the USB charge ports. Speaking of charge ports, the SolMate includes both a USB-A and a USB-C port, plus a switch to enable or disable the unit.
The case is all 3D printed, with some clever design choices. Offsetting the bulk of the battery and PCB storage area to one side lets the SolMate naturally cant toward the sun. Even the clip used to attach it to a backpack is printed.
Be sure to check out the other entries into our latest challenge!
Hackaday Podcast Episode 366: DOOM On A Toaster, Music In LED Strips, And Old Drives In New Clothes
It’s the evening before publication, and a pair of Hackaday writers convene to record the week’s podcast. This week Elliot Williams is joined by Jenny List, and it’s a bumper episode!
Of course, a bit of Hackaday news makes the cut, as it’s time to make an entry in the Green Powered Challenge. Then we make the first of a couple of sojourns into AI, as we talk about the Linux kernel stance on AI code. In short: if you submit AI code you’re responsible for its bugs. Meanwhile out of this world, we look forward to a time when astronauts breathe oxygen from moon dust.
There are hacks aplenty for your enjoyment, starting with far more than you ever thought it was possible to know about  sound-reactive LED strips. Then we have among others a Mac on an ESP32 forming the UI for a weather monitor, Doom on a toaster, and a fascinating look at screw threads for plastic.
In the longer reads we have our colleague [Tom Nardi] finding Chinese people’s personal data on hard drives he bought in an electronics store, and an attempt to look at what an LLM can do that might be useful. Grab your headphones, and join us!
Download your own Podcast!
Continue reading “Hackaday Podcast Episode 366: DOOM On A Toaster, Music In LED Strips, And Old Drives In New Clothes” →
A wearable circuit sculpture in the form of a smart bracelet that shows daily to-dos.
Wearable Circuit Sculpture Is One Smart Bracelet
Well, this might just be a Hackaday first. Certainly not the circuit sculpture part, nor the wearable aspect, but the glorious combination of the two. Behold [CMoz]’s Fashionably on Task: a Smart Bracelet for Forgetfulness. The name may be long, but the intent is concise: to showcase your top five must-dos for the day.
This lovely bracelet uses a tri-color e-paper display, and it’s WiFi enabled in order to receive input from the corresponding phone app. Although the cute pink ESP32-C3 is programmed in PlatformIO, the code will work with the Arduino IDE as well.
To get down to business, just power on the bracelet. If it can’t connect to the network you’ve hard-coded, it will broadcast it’s own access point. Connect with your phone to the custom web page, and Bob’s your uncle. From here, you can enter the tasks, change the colors around, mark tasks as complete, and remove tasks or reset recurring reminders.
The nifty part is that e-paper screen, since it will of course continue to display your list once powered down. Here’s the full code. Then you can deep-dive into the graph theory of circuit sculptures.
