How to develop for STM32 discovery boards using Linux
posted Oct 17th 2011 8:01am by Mike Szczysfiled under: linux hacks, Microcontrollers
Some hard work has gone into making it possible to develop for the STM32 Discovery board using a Linux system. The board boasts an ARM Cortex-M3 processor, which can be programmed via the mini-USB port on the side. But the company only supports development through their IDE’s which don’t run natively on Linux. The stlink project aims to solve this, providing a toolchain, and making it possible to flash the microcontroller via the USB connection.
The github project linked above also includes a tutorial to get you started (pdf). In addition to a walk through on compiling the software packages, it includes a simple blink program that you can use to test out your hardware. GDB, the familiar open-source debugger, is used to flash the chip. This is a bare-bones tutorial so if you end up posting about your experiences using this toolchain with the Discovery boards we’d love to hear about it.
[Thanks Texane]
Cool. I bought one of these but never did use it much, because it was such a hassle. Also, STM’s hardware driver library is really sloppily written.
