Photon Banner
The Revision 2011 demo party that brought us” table for two” a little while ago along with some super demos for PC’s, retro, and state of the art, has also brought us the Photon Banner(google translate). The Photon Banner is a 96X24 led matrix that was made with (of course) 2304 5mm leds, and a atmega 644 clocked at 20MHz.
The end result is a 192cm X 48cm display area that uses the single micro controller, that has been beefed up with 2 megs of SPI flash memory, 6 driver boards, and took about a month just to construct. The software to drive the show took another 15 days, and it is pretty darn impressive.
The website above contains a bunch of photos, parts lists, and schematics. Before you go running off you should join us after the break for a couple of quick videos.
Continue reading “Photon Banner”
Rebecca Black Running Accessory Also Promotes Running For Everyone Within Earshot
Last Friday, Friday we caught wind of [gvillenave]’s running accessory inspired by Rebecca Black, and we we we so excited, we so excited to bring this to you on Saturday, which comes after Friday.
[gvillenave] came up with the idea of using a song on the annoyance level of “Friday” to encourage a runner into keeping up a good pace. The concept is simple: if the wearer is running fast, the song will speed up. If the wearer is slowing down, the song will slow down and extend the agony.
The build uses an Arduino and [ladyada]’s wave shield coupled to an accelerometer. [gvillenave] included the code, and also wired up some LEDs to a pair of sunglasses that blink more often as the runner’s speed increases. The wave shield has a 3.5mm jack for headphones, but [gvillenave] graciously wired a speaker in, “so that you can annoy people around you, and not just yourself.” All this is packaged in a very nice 3D printed enclosure making for a great looking project.
There’s no word on the effectiveness of the negative reinforcement aspect of [gvillenave]’s build, but we suspect it will help her get down to the bus stop a little faster every morning.
Digital Picture Frame Reverse Engineering
coby_frame_hack
A few months ago [Jason] got his hands on a free Coby DP700WD digital picture frame and thought it would be fun to hack. After realizing that the frame did not run any sort of Linux-based OS he figured his options were pretty limited, but he gave it a shot anyways.
The frame came with a set of built in images, and his goal was to swap them out for pictures of his own. He started by trying to read data from the frame’s serial flash chip, but found that the processor was preventing him from doing so. He de-soldered the chip from the frame, mounted it on a makeshift breakout board, and started reading up on SPI.
He was eventually able to read the device’s flash chip and swapped out the built-in images with his own. After a bit of trial and error, he was able to replace the frame’s boot screen with his own custom image as well.
If you are looking to do something similar, be sure to swing by his site – all of the tools and code he used to hack his frame are available for the taking.
Continue reading to see his modified picture frame in action.
Continue reading “Digital Picture Frame Reverse Engineering”
