Robot can barely move with so much hardware strapped to it
web-server-robot
We think that [Andrej Škraba] needs to start looking for a beefier motor platform. This little robot has so much hardware strapped to it the motors can barely keep up. But with a little help it can make its way around the house, and it takes a whole lot of connectivity and computing power along for the ride.
The white stick on the top is a single-board computer. The MK802 Mini sports an A10 processor and up to a gig of ram. Just below that is a USB hub which is sitting on top of a USB battery pack. This powers the computer and gives him the ability to plug in more than one USB device. The robot chassis is from Pololu. It uses an Arduino and a motor shield for locomotion, with commands pushed to it via USB.
This setup makes programming very easy. Here [Andrej] has a keyboard and HDMI monitor plugged in to do a little work. When not coding it can be disconnected and driven over the network. He makes this happen using an Apache server on the MK802 and node.js. See a demo of the system in the clip after the break.
Comments
  1. blurybury says:
    looks so umm crazy tall and moves slow. whats the purpose?
    id run something lighter than ubuntu to save power. also get smaller lighter usb hub and use a dc/dc step-up to run motors off the main power pack ditching them 9volt batteries.
    get rid of them cables and use usb nano bluetooth keyboard/mice combo
    then add wifi camera XD
  2. dreamer says:
    Well, I guess it could be scaled up pretty well.
    Nice prototype, but horrible presentation :P
  3. tim says:
    presentation is actually alright. english is obviously not his first language, so he probably had some trouble getting his point across.
    very cool robot
  4. AlexHrn says:
    The builder might want to check out something such as the kitbots.com 1000rpm motors and Fingertech Tiny ESCs. With this combination I’ve moved 9lbs of robot.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 98,361 other followers
