Reader David Kristian was annoyed with having to use a full table or other object to support his half-rack effect when playing gigs. Laying the box flat made it impossible to read or tweak the device. He ended up with this mini-tripod. Replacing the pan lock screw and adding a suction cup foot created a really elegant solution. It gives a good viewing angle and it’s easy to pick up and take with you.
