IPod Transmitter Radio Modem
[Eric] sent in his iPod transmitter radio modem hack (Internet Archive). Given the short range of these FM modulators (and FCC rules) I’d call this an academic exercise. Combined with a few mods, it could be useful for bursting data from a micro-controller. (Think APRS)
Asus EeePC Bonus:About a week ago, [johnx] added (Internet Archive) a 16GB flash drive and a bluetooth adapter to his. Yesterday, [ta2cba] showed off how he squeezed (Internet Archive) a four port hub inside his – allowing a pair of devices to live in the extra min-ipcie bay and leave two ports to spare for later add-ons.
14 thoughts on “IPod Transmitter Radio Modem
  1. Digital on FRS Family Radio? No, not legal. GMRS is another story…the answer there is Depends…Refer to the FCC rules. I beleive some digital is allowed.
    BTW – If you really want to try this and use Linux, there are a dozen or so good sofware packages (generally available for most distros) that are free and do a lot more than just AFSK…RTTY, CW, Hellschriber, etc. Google hamradio software for linux and take your pick.
    How about a nice retro radio-teletype or RTTY “rf-modem”? Hook the output up to an old Daisywheel printer, and you are set.
  2. The first thing I thought of was sending NEMA data from my GPS unit (serial out) over GMRS radio’s and then decoding it on a PC. Would make a great tracking system for rocketry or UAV’s
  3. As VA3TSK mentioned, coupling soundcards to FM transmitters is already very common. I have done it multiple times, although the power and frequency are a little higher than the transmitter mentioned in the article. I have also built a couple tiny-trackers that connect to a GPS on one side and a radio on the other that transmit location of the unit (including my car – kc8ufv-14) on the (US/CA) standard frequency of 144.39MHz
  4. I like this wireless transmission idea! I was thinking, why couldn’t you simply use this circuit http://www.grynx.com/projects/simple-skype-voip-analog-adapter/ attatched to the modem and a teminal program. This gives you control over baud rate and you don’t need to write any fancy programs.
    You could also record the output of this circuit to a cassette and play it back to the computer to have an ultra secure way of storing data! (who uses tapes anymore?, who would even check?)
    Just my thoughts…
  5. In any gadgets with music I prefer using the ones with fm transmitters, because it is always good to hear brand new hit musics not only from the ones you have downloaded but also you will not be bored to hear the same thing again shuffling from your gadgets.
Leave a Reply to KC8UFVCancel reply
