[David] put together this rather nice 1-wire barometer. An MPX4115 measures the pressure while an SMD DS2438 mounted to an 8 pin DIP socket provides the 1-wire interface. The writeup includes a nice description of the board layout and wiring, making this project accessible to just about anyone with a decent tip on their soldering iron.
4 thoughts on “1-wire Barometer”
Leave a Reply to pipCancel reply
If you don’t have a decent tip on your soldering iron, get a pre-made TAI8570 from http://www.aagelectronica.com/aag/index.html?target=p_21.html or some other place.
Since my comment regarding where you can buy this was removed, can I atleast then inform that this hack is *old* and the same guy also has a 3.0 version on his site: http://davidbray.org/onewire/baro2030.html or is it offensive?
I see 3 “wires” there, power, and two phone lines.
Pip: If you read the article you’d notice its for a so-called ‘1-Wire’ network, not that it uses one wire.
