For those unfortunate few of you who don’t already have a plasma cutter sitting around, [jandgse812] is here to help. He walks you through the process of building your own plasma cutter from scratch. Adding up the list of parts brings the total project to roughly $300. He has included visual diagrams for all the wiring as well as specific part numbers and where to get them. Be careful, this is potentially very dangerous, but also very cool. You may need to get a copy of the mission impossible theme to play whenever you use it. At least, that’s what [jandgse812] recommends. You can see a video of it in action after the break.
[youtube=http://www.youtube.com/watch?v=kY7P9v24HqE]
He WAS selling these plans for about $20. I guess he changed his mind, looks pretty cool and lord knows most of us already have or can get these parts. MUST HAVE THIS.
this is one of those posts that has the potential to do a great deal of creative damage. Nothing within my garage is safe anymore. Thanks for the post!!!
Best thing I have seen in a long time. This is my kind of hack!
This is very cool, all it needs is a dual axis computer controlled thing. Since it is all homebrew it would be easy to adapt to that.
*YEE GODS!!!*
That thing needs a cover on it. That looks just plain dangerous. Extremely cool but extremely dangerous. Just imagine your surprise if you back into that setup while working.
Cool i’ll use it to light my bong.
Just a word of warning, these are a hell of alot more dangerous than mot spot welders and most other diy welding equipment.
Found a word of warning from this guy in the comments on a spot welder instructable:
http://www.caringbridge.org/cb/viewMyStory.do?method=executeInit
Just be careful not to vent plasma through the secondary feed vents. it upsets the drive.
just sayin’
@Comedy Blog and iiCrItAkKaLzZzXbL
high or not, neither of you are funny. leave.
This set of plans has been around for sometime now on Yahoo groups. Although you have to now buy the plans to get to the private section. It was publicaly viewable at one time.
At least he is not using the water resistor like the first implementations used. This way is still very dangerous as you can come in contact with the hot side of your work and ground very easily and get a 400+ Volt DC shock.
This is because most modern devices like this use a isolation transformer which is center tapped to ground.
This is the best hack I’ve seen a in a long time, I have all but about 3 parts + the gun to get this made i’m very tempted to make one of these! This is the kind of stuff I like to see
Although this is an excellent project, it’s definitely not for the hobbyist. i wouldn’t recommend trying this unless you already have a good deal of experience with plasma cutters and high voltage projects. there are about a dozen ways to kill yourself building and operating one of these things.
There is a 40A plasma cutter on ebay for $300 that I think I would take over this death trap.
But still very cool to know that it requires relatively few and common parts (as he points out).
You can buy plasma cutters for the $300.00 in parts you need.
I guess if you had a nice stockpile of freebies around it would be a good idea, or if you are trapped in a electrical/electronic wearhouse and needto cut your way out you could build one.
I’ll just buy one, you can get really good ones used for around $150-$350 if you look hard enough.
I love the smell of vapourised steel in the mornings!
coincidentally, its also the smell of cancer.
The link provided says removed by author.
If someone downloaded the pdf of this guide before it was taken down, could you please upload it to some file sharing web site and post the link here?
Thanks
I know these are old post but this is my cutter the Plasanator.
What you are looking at is the cutter on a test rig.
I latter enclosed it into a box.
I have up dated it alot and I even have a working lab unit foresale on ebay at this link.
Thanks for all the great feed back. Joe
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130343366476
This instructable has been removed
i would sure like to purchase a set of plans for this –i tried to build one with another set of plans but the wiring confused me as there are two many junctions–if you will sell me a copy of these please email me how to get them
kind you email me a copy of components and list of material and diagram to make a plasma cutter??? please i beg you…^^
