Desulfator In An Altoids Tin
desulfator
If you’ve ever let a car sit for a period of time and returned to find that the battery was mysteriously “dead”, you were probably experiencing a sulfate crystal build up. Often, people just buy a new battery and plop it in, but that isn’t absolutely necessary. [Kmpres] takes us through the process of building a desulfator. A desulfator works by putting high voltage pulses into the battery forcing the sulfate crystals to dissolve back into the electrolyte. From what [Kmpres] says, you can find “bad” batteries in all kinds of places, use the desulfator on them and have perfectly fine batteries when you’re done. You may recall doing something similar with a disposable camera.
IR Controlled Light Dimmer
dimmer
This is a pretty useful device. It is an IR controlled light dimmer. It goes in line with the main power and controls how much gets through to your light. You can adjust the brightness with a TV remote control. Finally, we can retire our clapper! These are commercially available, but making your own is just so much more fun. You may have to dig a little on their site for the schematics and programming. There are tons of other projects there as well so have fun.  You can see a video of it in action after the break.
Continue reading “IR Controlled Light Dimmer” →
