More Cellphone Controlled Door Locks
[Tom Lee] and his colleagues just moved to a new office. The doors are setup like a security checkpoint with electronic strikes and buttons on the inside to allow entry. The button simply completes a low-voltage circuit, activating the strike which made it quite easy to patch into. They build an interface board with a small relay to complete that circuit. As we’ve seen before, Linksys routers have plenty of extra room in the case so there was no problem housing the new circuit in this tiny network device. Now [Nicko] and his friends can use a custom app to input an access code or to verify a device ID from a cell phone and gain entry. The door still has keyed locks in case of a power outage. In fact, the only change made to the system was the addition of two wires to the “door release” button as seen above. See the one-touch device ID authentication in the video after the break.
This hack is similar to the GSM door entry from last year. In this case, the phones are communicating with the door via web interface and not the GSM network.
[youtube=http://www.youtube.com/watch?v=6BUTK1c3L8c]
[Thanks Nicko Margolies]
16 thoughts on “More Cellphone Controlled Door Locks
  1. nice hack, guys.
    i especially like the simple and thoughtful hardware used rather than overkilling it with a uc.
    not to mention the banana plugs on top are pretty sweet. very frankensteinish :)
  2. Transistor Q2 is lacking a freewheel diode.
    Yes the relay (seems to) contains an internal diode, but the transistor needs one too.
  3. I appreciate the comments! smoker_dave: maybe you could elaborate. I confess I don’t understand why an additional diode is needed at Q2. I may have selected the wrong part in EAGLE, but I meant to signify that there’s a diode connecting the terminals of the relay coil in the direction opposite to (normal) current flow. The collapsing field should be able to flow through it and short out, yes? I’d think it wouldn’t affect Q2. But I’m no EE; would definitely appreciate a chance to learn what I’m doing wrong.
    therian: If you read the post you’ll see that I’ve built systems exactly like the one you’re describing (I was using a Fonera, though). But it wasn’t necessary for this project — and, for whatever reason, I was having some trouble with the serial port when on this router when I tried it (I might’ve fried the UART accidentally — can’t figure out what else it might be).
  4. Tom:
    You may want to add a base resistor to Q1 (between the base and pin 5 of the 556). Not sure if it just got accidentally left out of the schematic, but a tip in case you didn’t know: the base-emitter junction of a transistor acts like a diode when forward-biased, so without some resistance it’s essentially a short.
    You should probably also put a small (few hundred ohms, maybe) resistor between Q1’s collector and +5V. The reason I say that is if the comparator and Q1 are both on, since the comparator is open-collector output, you essentially have a dead short from +5V to ground. Poof!
    That might explain the problem you’re having with startup..?
    Also, excellent work! I don’t hate Arduino, but it’s refreshing seeing that people still design circuits with ’em ;) In any case I hope I helped! Good stuff you’ve got there!
  5. @googfan They say that the keys are “expensive” yet they say their system can be controlled with, and is demonstrated by, a $560 smartphone and can be used by iPhones as well.
    If they can afford $600 phones I feel the employees can sure as hell afford the keys that are most likely $20 HID RFiD keys.
  6. @Eric: thanks! I’ll update the schematic. One other thing I realized I left out: a resistor between the comparator’s output and the 556. Otherwise you could wind up with a dead short when the first timer is active and the door fires. I think this lets the timer “win” — although come to think of it, maybe I don’t have a big enough resistor in there. I’m increasingly tempted to update the schematic and make a revision of the project my first attempt at a homemade PCB.
    @DC: well, not everyone in the office has a smartphone. Some people have bought them for themselves; others have developer phones donated to the organization. And other people just have regular phones — that’s why we have the Twilio interface. Either way, it’s infrastructure that exists, so we might as well build on it. The keys are expensive to duplicate. And we didn’t want to jump through the hoops of installing an RFID reader outside of the door — this didn’t require permission from the building management, or any construction equipment more involved than a screwdriver.
  7. @DC also: yeah, it’s not HID, or any other RF technology. The keys are actual keys — some kind of security model that’s expensive to duplicate. We’re stuck with it, unfortunately.
  8. @Eric: ah, now I see what you were saying about Q1’s collector. I think the missing resistor on the collector output takes care of this. The alternative is to have pin 8 able to short to ground even when it’s supposed to be getting pulled high by the timer.
  9. “They build an interface board…”
    Should be *built*, unless they are now building and selling these…
    Cool project though. I’ve always loved the idea of using a router for physical world control, I’ve just never had anything I really needed to control that way. Nice job though!
    -Taylor
  10. @googfan
    No a key is not hard to use.
    However 70 keys ARE hard to manage. If someone is terminated, did they turn in their key? Did they make a copy? What if a key is lost, do I rekey the building (at a cost of thousands of dollars)?
    Maybe I want to allow access from 8-5 Monday – Friday and allow the Cleaning Crew from 9-11 on Monday Wednesday and Friday.
    Then there are those that forget things like keys, but miraculously always have their phone.
  11. The doors are like a set-up strikes and electronic security control buttons in the entry permit.
    The button just completed a low-voltage circuit, the activation of the strike, which made it really easy for patch.
Leave a Reply to neversayneverCancel reply
