IPhone Drum Machine Isn’t Synthesized
There was a time when a drummer would grab some sticks and lay out a groove using the items around him as instruments. [Lsa Wilson] would rather not work quite that hard and has chosen to do the same thing by tapping on an iPhone screen. As you can see in the clip after the break, many of the items in the room around him have been fitted with solenoids. Each is connected to an Arduino which is then controlled by Open Sound Control and interfaced with the iPhone via TouchOSC. We love the sounds being created and can’t help being reminded of the Multixylophoniomnibus.
11 thoughts on “IPhone Drum Machine Isn’t Synthesized
  1. Touch OSC has been around forever. I control DJ gear with it.
    Cant believe people are only now “discovering” it.
