Daft Punk Table With IPod Dock
This beautifully crafted Daft Punk table with iPod dock was built by [Dustin Evans]. The table itself was built with the help of a friend in one day with electronics added a bit later. It features an 8×8 grid of boxes with red LEDs mounted inside. The picture above is not quite the finished product, a diffuser will be added later to augment the scattering of light already provided by cutting the tip off of each LED. On the underside you’ll find a power supply and a set of speakers. The system is controlled by an Arduino which resides in the same drawer as the dock. See the final product in the clip after the break.
[youtube=http://www.youtube.com/watch?v=ksVysIMQl-4]
[via HackedGadgets]
35 thoughts on “Daft Punk Table With IPod Dock
  1. Great work! Nice looking and functional too. I wonder if this thing could display the Lyrics of a Song or something a little more interesting to watch? On the other hand, if all you want is to have a Seizure… then this should to the trick!;)
    Don
  2. OK +1 cause personally its an outdated fugly table, and now its “smart”
    otherwise I dont fully understand “draft punk”, and I would be embarrassed to go through all the trouble and shoot the video with a dead segment
    really, its not going to kill anyone to not see this for another week
    turdly good work and I hope you learned along the way
  3. The table came in pieces of wood. We cut the holes, put the whole thing together, made the grid, hand soldered 64 leds after cutting the tips of them off to defuse the light, painted the grid, and varnished the wood for the table. The drawer was also built by us. The only thing that wasn’t made by us is the legs and only because we didn’t have a lathe we could use to make them. -Dustin
  4. vonskippy, in order to show that I do have some form of a since of humor down in my cold black heart I often use turdly, and you might see testically as in the following
    “testically speaking that should be OK but you might want to check your voltages”
  5. Now that some one made this Table with red LEDs, whats to stop someone else with maybe more cells and some RGB LEDs from taking it a step further.
    And make the flashing visualizations go in sequence with the music. Is any who here is willing to try?
    An important part of hacking is not just the successes, but the failures (and to learn from them). Isn’t the purpose of a hack is to expand or re-purpose the function of a item outside of it’s intended use?
    Although I did like the concept of the table, and the skill to get this done is great. Dead LEDs happen.
  6. @Alex: I hear you! Stupid pixel way down in the bottom right corner, still catch glimpses of mine! One pixel, and I cringe. The table… It must be destroyed!
    Seriously though, I’m gonna write “Daft Punk” in marker on my fridge, and submit a video of me opening and closing the door, WITHOUT a song of theirs playing in the background. That’s pro right there!
  7. @sd
    This is almost nothing like the actual original Daft Punk table. That had a black reflective finish with the LEDs off, and large cells that went almost edge-to-edge. This has a wooden finish and a small inlaid grid of blinky LEDs in the center, which looks like a white grid when it’s off. Hardly the same at all.
    The Daft Punk table was so-called because it was actually DESIGNED by the Daft Duo. Not because it had blinky lights.
  8. Around the world, around the wooooorld.
    Either way, I’d like to have this in my living room.
  9. you should consider doin the hole table to the edges and just use 1/4″ sheet metal as your crossbeams and to make the boxes then lay a a frosted glass on that baby
    and you have even a sicker table
  10. Wow I thought he repurposed some ugly 70s table and some junk laying around. If that was the case I would say great way to spend a boring weekend but then I saw the build pics. Its disturbing that he built the table and calling it daftpunk is blasphemy!
Leave a Reply to mjrippeCancel reply
