When you see $125 off something you probably assume it cost several times that to start with. Nope, this drastic discount leaves just $25 plus shipping. Use coupon-code: 2JLP-R4XRT3 when ordering the little rover. There’s a quick video snippet of it embedded after the break.
What you’ll get is a Stellaris ARM Cortex-M3 microcontroller on a board with a bunch of goodies.
- MicroSD slot
- USB host and device connectors
- I2C audio with speakers
- Ethernet connector
- 96×6 OLED display
- Motors
- Optosensors
- Bump detectors
As always, we want to hear about the hacks you come up with once you have this little guy in hand.
[update, the code is now expired]
[final update — Someone from TI explains what is going on.]
—- from the comments.
As some posts already note, the coupon code is only available to ESC Boston attendees. That said, we’re psyched about all of your interest and understand there seems to have been some confusion, so TI plans to fulfill all of the finalized orders to date. We’re working on some logistics in getting the code up and running again for ESC Boston attendees, but proof of ESC registration will be required. Stay tuned.
We hear you about the e-store and are working as quickly as possible to avoid issues in the future. Thanks for your patience.
Bottom line – we’re glad to see the excitement around EVALBOT and look forward to checking out your projects! We encourage you to share them on our e2e Forums at http://e2e.ti.com/
-Jean Anne Booth, Texas Instruments
[youtube=http://www.youtube.com/watch?v=dQPyZPQcyKI]
[Thanks GDM]
Order number 6005.
For anyone asking about being able to program it: gcc can generate binaries for ARM; while you may need to compile a cross-compiler, you shouldn’t need to buy software. Also, the steps for compiling a cross-compiler aren’t actually difficult, and are well-documented (not to mention many distros probably have packages for arm-gcc crosscompilers, since it’s quite common to develop for the ARM).
What a painful process! I finally got through with order number 6011.
What a joke gave up after 1 hour. You think they could afford a better server. I kept getting I am a bot. Might help if they let you know that when you clicked the submit button you are suppose to sit there even thou no prompt on screen displays letting you know it is “working”. lame
Order # 6043 went through at 3:53 PM central.
Yep, still works. Just ordered mine.
Order number 6012 in the email.
It gave me the bot thing though, but my order still went through?
6060 … hopefully?
Sure took a while to get that order through! :)
Mine was finaly accepted. Order number 6058.
Bet they did’nt expect to sell that many so fast :)
Order 6050. Took almost 2 hours to get through.
I’m in the UK.
Took me an hour and ten minutes!! I got the bot detected….. Then it said code already in use…
then it hung…. then I started again… I was clean shaven when i started… I have a ZZ Top beard now. The rule is: Preservere! $25 to the UK!
thats about £16… Cool! Now, I can finally start speculating about whether it will ever arrive!
Awesome!
The page locked up after I clicked “pay with card” but I got a confirmation email, #6067.
OOP’s mine was order number 5977
6081, damn you long sushi lunch.
I’m just hoping my order will be shipped.. eventually
Guys… One silly question… Anyone got uclinux (looks like this shit has no mmu) running on it? That uCOS thing sounds to me like some complete proprietary crap (not looked much in it so far) and uclinux would be just the thing.
Number 6028, still plenty of people getting through it seems! took a while though of course…
FINALLY
order #6073
Having waited 3 months for the MSP Launchpas, I don’t even try to get this one.
I’ll do my own with a ST Cortex-M3 sample that I got for free in two days
have they disabled the code? I arrived at the payment page, copied in the code and clicked apply, after several tries (3 minutes each), nothing happened, still 149$…
(also at some points the website dumped parts of its C#-code?! you have to *actively enable* that on production websites, their admins/developers must be mental…)
order 6123. took some time & one bot warning.
Also the checkout process changed the layout in the process.
order #6138 via email conf/checkout page. coupon still worked.
what about company?!
i used the website of http://127.0.0.1 on the customs declarations page. could they actually be checking the url your entering?
Order Number: 5775
So having trouble placing an order….
Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3614
THERE’s you problem. I feel dirty just reading the letters ASP :(
order #6146 :)
I finally got through! One little bot ordered and ready to go, hope they don’t check the URL for customs, I said N/A LOL! Oh and for those having trouble, coupon still worked for me.
Order #6154
Took me a good hour to get it to work, but I got it.
Thanks HaD!
im order 6177. just went through.
Just ordered mine. #6163 (which, incidentally, is the old PIN code for my former bank card. coincidence? I think not ;-)
But I’ll only believe it when it arrives. ~18€ incl. shipping to Germany sounds too good to be true. We’ll see…
@Greenroom: Sorry hab deinen Post erst gelesen als ich schon bestellt hatte. Hast du inzwischen jmd. gefunden der dir einen bestellt?
can’t seem to check out. it just says ‘processing’
Order Number: 6141
Ordered on: 10/4/2010 4:35:57 PM
#6153
I tried forever and was just about to give up because after finally being able to fill in creditcard info it kept erroring
all in all after 90 minutes of frustration finally got 1!!
Hopefully the damn thing is worth it :D
Order 6202… After many many tries
I wept without shame when my first attempt failed, but persistence paid off, it’s been quite an hour.
Low #6200’s for me. Surprised they weren’t out of stock, or that the code wasn’t revoked, or that I could actually get and print my receipt on their website.
Huh, it’ll be forever until it arrives, won’t it.
Order 620x
Got through eventually. Man but that site sucks badly under load. Coupon still working.
Order Number: 6110
Took a little while to complete but another great deal from TI.
Site seems to be speeding back up, 5 min.
How long to the UK??? but for £15.80 + free shipping i don’t mind to much. anybody have a schematic so the UcLinux port can get underway?
I can not find any documents or links to details about its development system. Development tools found for other Texas Instrument microprocessors are not in the price range of hobbyists (and amateurs).
I did tried to order one kit in order to see if there are more details after registered for this purpose.
It looks like their websites were running on a 4-bit processor (or this kit!). And it has an endless loop bug at “Check Out Now” phase, I have selected this button and it kept redisplay the same screen without acting on it or reject this action.
Goodbye and good luck TI.
Just ordered mine! tried to order a second one but the coupon is only good for 1 unit. Oh well, at least I got 1 :)
Order #6180
6232. Let’s hope I don’t get hit up for UK import fees.
Website seems to be working a bit better right now.
Order number: 6263
@Paul – There’s a fantastic picture here:
http://focus.ti.com/graphics/tool/Evalbot_Rev_A_perspective_Image.jpg
imgur’ed just in case TI’s servers can’t take the load…
http://imgur.com/5bFYM.jpg
Discount went through, but can’t click the stupid “Pay With Card” button!
Does anyone have any official reference for the deal, like when it expires? I want to be able to call them up tomorrow and say “Hey, your webstore was down, but I wanted to get in on this deal.”
sweeeet, after some frustrating retry/ail/reload I got through and — $25, free shipping even to ICELAND! I wonder what will do with it.. I say it should be something to do with home security mounting an old htc phone on it,… or… semthing to do with beer something something… nice
@kemp
Wouldn’t it be below the threshold?
yes.. and order #6266
@Xandrios
The Stellaris is an ARM cortex M3 core, to program them you will need FREE compiler CodeSourcery Lite. Get the ARM-EABI version, not the linux one (Different C libraries, the non linux one uses newlib which is better for embedded).
Also, whilst I can’t speak for this kit my other Stellaris boards program just fine with OpenOCD using the libFTDI driver.
@SomeEvent
Yeah, I’m just hoping that TI don’t write the original price as the value.
@kemp
http://www.dutycalculator.com
