AVR HV Rescue Shield 2
[Jeff Keyzer] has a new version of the HV Rescue Shield available. This tool allows you to use an Arduino to reset the fuse bits on AVR microcontrollers. This is necessary if you make a mistake and disable the reset pin, or choose the incorrect clock settings (this will probably happen to you at some point). In order to bring the chip back to life you’ll need to use High Voltage Programming. The last version of the shield only worked with High Voltage Parallel Programming (HVPP) but this rendition can also use High Voltage Serial Programming (HVSP) for 8-pin chips that don’t have enough inputs for parallel communications.
As we talked about in our AVR Programming Tutorials this is no replacement for a high-end programmer like the STK500 or an AVR Dragon, but if you already have an Arduino a kit will only cost you $20 (or you can etch and build it yourself). We would have liked to see a breakout header for the HVP signals for off-board use. The absence of a breakout header doesn’t preclude this, but since you need the on board boost converter for the 12V signals, and because this shield can’t be used with a breadboard due to pin spacing, it’s hard to patch into signals for non-DIP use. We also think some clever firmware hacking and this could be used for HV programming, like we needed for that LED light bulb.
10 thoughts on “AVR HV Rescue Shield 2
  1. i have never set a fuse wrong but there is a first for everything (knowing my clumsy ass) but do they sell these things as commercial standalone products?
  2. $20 for a board to rescue a chip thats worth considerably less than that? Looks like youd be better off just breadboarding this. Why would you want to go thru the pain of ething a pcb for this? Surely you should spend that effort not programming it wrong in the first place. Or have i missed something?
  3. Perhaps it’s the Lazarus Effect. Restoring life to a bricked chip gives you an awesome feeling. Yeah, you could buy a Dragon or throw this together on a breadboard, but a quick plug-in solution for that Arduino you already own has its place.
  4. maybe you were doing a small production and things went wrong, this could help
    or maybe you could get a ton of dissabled avrs for cheap and just restore them
    i like his dc-dc converter there
    jeff’s pretty cool
  5. OK, I’m dense. The appeal of these things is that one can reset fuses without leaving arduino-land.
    BTW, where’s the $25 USB STK500 clone?
  6. Guess its a good thing I live in the silicon desert…got my stk500 for $2.00 at goodwill…still trying to find time to play with it to see if it works, but it powered up!
Leave a Reply to BrentCancel reply
