Light LED’s With FIRE!
Reader [Andre] sent in a link which tells us all about this “cool” Copper Oxide Thermoelectric Generator. All you need is a bit of solid copper wire and a gas torch. Burn the wire so it gets a nice coating of oxide. From there, it is a matter of making the 2 sections of burned wire cross at a point and heat up only one of the wires. Whichever is hotter forms a cathode and whichever one is cooler is the anode.
Just one of these junctions is enough to produce a few hundred millivolts, but the author takes it a step further, well 16 steps further. He made a ring of these junctions in series, which is enough to light a bright blue LED. While the author notes that this thing is producing a considerable amount of voltage, its not producing much amperage. This could come in very handy in the future, like if you need some additional LED lighting for your camp stove.
30 thoughts on “Light LED’s With FIRE!
  1. I was about to submit this one myself. It is from the same guy that charges old refrigerators with propane and makes his own miniature CRTs.
    I will have to admit that I disagree with his explanation, though. I think (and I have no real way to prove it without my GRC Handbook handy to confirm the dielectric potentials of the materials involved) that the real cause is heating a dielectric junction between cupric oxide and cuprous oxide.
  2. I like the idea but it seems like there would be a more energy effcient way of using that many therms (boiling water minature steam generator …hey you could do both at the same time) I ponder how much power could be created in a chimney configuration with 10 plus layers of these stacked together ?
    1. It’s just the American way – I don’t really like it either but I also don’t like Voltage and that’s pretty much accepted everywhere now.
    2. amperage; part of the DIY community “Ebonics” vocabulary, IMO the small stuff not to sweat. I have to admit saying in my mind, it’s current dammit not amperage, whenever I read the colloquialism amperage. Who am I to judge? I likely to say x amount amps to denote the amount of current flow rather than saying x amount of amperes.
  3. If you run a current through this assembly you get a temperature delta across the layer. Can be used as heater or cooler (actually both at once). I’m just not sure about how efficient it will be compared to commercial peltiers. What also works is running an am or fm receiver from a candle…
    1. Luke has a pretty interesting point there. I’d imagine you can somehow apply this to a coilgun to keep it cool, mine tend to overheat and fry the coils, as well as generate a bit of power to help charge the capacitors. I’m going to have to look into this. Do you think any other easily obtainable combination would work (I can’t just pick up some rare earth metal or something like platinum or some crazy alloy from the local hardware store, ya know?) better than the copper oxide. To Andre, pretty inventive stuff. I always though of peltier junctions as some hunk of silicon that’s only good for cooling your PC. Nice work! I apologize for the long comment.
  4. It would be interesting to try this with some cheap high temp thermocouples (type K maybe?) and compare the results.
    1. Amperage is perfectly acceptable in the engineering world. I’ve heard my professors use it interchangeably with current many times at engineering school.
      The same thing happened with expressing the ability of something to a constant level of current. The correct term is ampacity, but everyone just uses current rating or current limit.
  5. I remember being fascinated when I was little by something like this in my mother’s old World Book encyclopedia from many decades ago. Only difference is they used a candle instead of a gas torch, and they powered a radio rather than an LED. Wish I could remember how that version worked though; my parents got rid of that encyclopedia years ago.
    1. Early 60’s before hookah times our Catholic grade school got new ‘pedias and there was the picture of a circle of people in India lighting up and listening to the radio. No electricity then, it had a ring of radial thermocouples 20 or more. I can’t remember if it had plans to make it. There is probably a federal violation here. ICE’s run hot, great app!
  6. That is pretty cool. otherwise wasted heat could be used to generate usefull electricity.
    Isn’t this a “Type-U” thermocouple? copper & copper. The Seebek Effect – a few millivolts are generated proportional to the difference in temperature between two wires…(I acknowledge ino for saying so earlier too)…
  7. Just so there isn’t any confusion, I didn’t come up with this, just found the page when searching.
    @Dylan Pretty clever, but..
    Surely the light from the sky lantern itself would drown out anything from the LEDs.
    Unless you used like a 5W RGB LED for each?
    Sky lantern radio transmitter OTOH… :-)
    One crystal oscillator, 10 foot wire antenna and voila!
    @nave.notnilc Yeah, have seen this done.
    Its interesting to note that your choice of wire affects this- some wire has added beryllium or other metals which mucks things up or so I hear.
    Someone should try and make a PCB version of this,
    using the copper substrate as one electrode.
    Seems that its the contact area which determines the current, so put several treated wires touching the one copper plate.
    -A
Leave a Reply to Urza9814Cancel reply
