[Martin] sent in two videos he found while cruising the tubes. The first video is a simple circuit with a resistor, three switches, and three LEDs. All the components are soldered together right in front of the camera. When a battery is connected, turning the first switch on makes the first LED light up. Turning the second switch on makes the second LED light up, and the same thing goes for the third switch and LED. Obviously we’re dealing with powers that are incomprehensible with even several cups of coffee.
The second video features the same resistor/switches/LEDs, this time in a parallel circuit. Turning on the first switch makes the first LED light up, and the second switch makes the second LED light up. Truly we are dealing with an expert in troll physics.
This is probably something really benign and uninteresting, but it sure is enough to wake up enough brain cells on a Monday morning. We’re not going to hypothesize, so check out the comments where we expect the correct answer to be.
[youtube=http://www.youtube.com/watch?v=RkTvDjhImwo&w=450]
[youtube=http://www.youtube.com/watch?v=OoPCDiMF108&w=450]
Invisible wire ? Impressive from my perspective.
Would like to know the answer.
Here’s the Solution to the 3 LED one. Its quite ingenious. If only I knew more about electronics and circuits.
http://www.youtube.com/watch?v=mzDTZuFJYX4&feature=relmfu
Excellent illusion. Back in the day when I used to teach electronics, this would have been great to spring on DC students right after their introduction to series circuits, and then pulll back out after they had completed AC and Semiconductor Theory to explain the solution. Nice job hiding the circuitry – I correclty assumed that you had done that, and that the solution had to do with AC, filtering, and polarity sensing/recitification capabilities oof the LEDs, but that’s as far as I got. Had to Google the rest. I would never have come up with this design by myself. Very creative!
It’s always AC in these “tricks”, I got trolled by my teacher, never again!
all i can think of is that those aren’t normal switches.. but even then. WHat the heck.
Pure camera trickery.
Occam’s razor says this must be it.
I call on Adobe After Effects, object tracking plus Picutre in picture. Noticed how the lit leds are a big bigger? ;p
I am pretty sure that visual effects are easier than microscopic components or modified leds. Notice how careful he is about the positioning of the leds before flipping switches. I see the plausibility of the modified leds, to respond to specific voltages or frequencies. Though, if the goal is to confuse the viewer with simple science gone wrong, tricky editing seems like the way to go.
Maybe the wires have multiple layers to them to create separate paths for the power to flow through. But this still doesn’t make any sense to me. Interested in finding out how it works.
I like this answer, and it could work since the wire lengths were all pre-cut, but the lengths are too many and too few solder shots to make that plausible.
HINT: What if the switches aren’t really switches?
Author writes (in Polish) that the switches are actually manipulated.
So, can it be that the switches and LEDs always let current pass and the switch when ON just send a RF to the LEDs that have a normal LED that turns when it receives the radio signal and a wire with the same resistance as the LED when not receiving the signal?
Sorry for my bad English
Expected behavior:
Series: all switches must be closed in order for current to go through the LED’s and either all 3 are on or all 3 are off…
Parallel: if either of the switches are closed, there is a short and both the LED’s will be turned off, otherwise both LED’s are on, but with a slightly brighter value ( assuming resistance is unchanged ) since we have the same voltage across both.
How does it work in the video? Adobe After Effects of course.
Either that or I don’t know circuit theory.
Judging by the use of a nice high contrast background, I’m going to go with post video editing.
It would be conceivable to make led’s that only operate at a specific voltage because of some internal circuitry.
It’s also possible that the 9v battery has some “extras” stuffed into it as well.
That’s what I was thinking. Are there frequency sensitive LEDs? Maybe there’s three inductors in the battery, a battery and some circuitry. In the switches there could be an inductor and a capacitor. There might be other components, but the basic idea seems plausible.
My first instinct is to say that they’re cheating somehow; basic electronics knowledge says that shouldn’t work. However, I am not one to lightly throw around accusations. Maybe it has something to do with the diode effect of the light-emitting diodes in the parallel video, but I am at a loss for the series video. In any case, they’re certainly fun videos, and good for getting the mind going on a Monday.
I’ve had another look, he’s moving the circuit too much for video editing (I think) and even if those aren’t switches, what are they?
Easily done in Adobe After Effect, all you have to do is use motion tracking and whatever effect you apply will follow the object’s slightest movements. I’ve done it myself on much lower quality video.
Strictly a video troll and not even worth giving his channel views from HaD traffic.
The links to the video should be removed.
@raidscsi Uh, calm down dude. The video is fun. We know he’s tricking us. Its just a magic trick.
Do you think all Magicians are just trolls and we shouldn’t be linking their videos and giving them traffic too?
He made a fun little puzzle for us to figure out, there’s no reason to avoid giving him channel views.
You could probably fit a tiny coil in those switches and in the base of the LEDs alongside a SMD transistor.
A simple way will be adding the light in the video with after effects
@mythgarr, I was thinking that perhaps the switches were current limiting, rather than on/off, and that the LEDs can only operate at a specific level of current, but I can’t explain how they can all work at the same time.
Hey i was thinking that too.
Maybe the switches have some voltage varying effects, and the LEDs thus lighten up when their corresponding switches are turned on the allow their effects
I’ve watched the videos for 2 switches & Leds in series, and 2 switches & Leds in parallel…
The battery is not just a battery – it is a low voltage AC source…
In parallel – the switches have been modified – they have an internal diode that is shorted out when the switch is off – each switch has a the diode a different way round – the Leds are not the same way round..
In series for just 2 switches the switches when on short out a diode – the leds have a very small surface mount diode across the legs – some surface mount diodes are very small…
3 switches – No Idea…
I think you’re on the right track thinking that the battery is not just a battery – it is a low voltage AC source…
Especially since in one of the comments the author says “Hint: do you know any AC current properties?”
I also noticed, on the first video, 2:05 when he touch the wire the first led barely lights up.
This is the phenomena of wave signals. Probably there are some inductors and filters.
My guess that the battery is just a secondary coil inside and there are a primary coil behind the table.
Definitely on the right track, both battery and switches has been re-worked the battery is just a shell which contains an atiny and the switches has been re-worked with smt diodes inside of them.
I am majoring in Robotics and Embedded Systems right now. I have done tons of circuits in the past. There is definitely some trickery here. These circuits would not work the way displayed.
My guess is very good editing. The parallel circuit video had one LED not pointing at the camera, but it was just as bright as the LED that was pointing at the camera.
I’m a hobbyist that’s totally lost without an arduino and i have an idea of what’s going on behind the scenes.
aka. you don’t have to study electronics for very long to see that this is odd :p
Line Frecuency diodes, Controlable Switches with Zener diodes. Thats it. Direct Current Source. Differente values for each pair of Switch-Line Frecuency Diode. Electrical/electronic Engineering Knowledge, in that video, sad, that it doesn’t have real life applications. :(
There must be an Arduino inside that battery. ;-)
Would it be feasible for the leds to only light when they are fed a certain frequency of current, with each switch thing filtering out those specific frequencies?
…or generating those frequencies, I suppose the paralel circuit wouldn’t work if they were filtering.
There’s a very small jump in the first video as he takes his hands off the screen and absolutely anything could happen before he splices the video back together, including substituting a different circuit that looks the same from above.
The second video isn’t as noticeable and he keeps his hands on the screen, but it could still be a substituted circuit, wired in the way you’d expect to achieve those results.
…Maybe a small diode was installed in the switches? But that would only account for 2 leds…?
(the video isn’t clear enough to see the polarity of the leds)
for the first circuit –
1) let the battery realy be a small ac supply.
2) put a diode inside each switch in series with the contacts, miss-label the on/off sides, have the diodes be opposite in polarity orientation for the switches.
3) have the LEDs have opposite polarities so each lights on alternatre AC half cycles.
4) an open [realy shorted] switch prevents it’s LED from getting enough voltage to light due to it ‘shorting’ that half cycle of AC. Close [realy open] the switch, and the AC is alavible on that half cycle to light the LED.
I haven’t thought it through yet, but I was leaning in this direction as well, but reverse labelling the switches makes it all sound a lot better. The LED direction and zeners helps pull it all together
Maybe some of the wire is non-conductive.
On the one hand, it’s sort of irrelevant _how_ it’s done, since we all know that’s not how circuits usually work. So it’s pretty obvious he’s doing some sort of trickery.
That said, which trickery sounds easier to execute: Careful, difficult modification of components so that the end result looks completely ordinary, or an hour or so with Adobe After Effects?
Of course its relevant how it done – that what makes it interesting (or not.) And plenty of people do tricks “the hard way” since it’s much more interesting that way.
I vote for custom trick wire; logic dictates that the 3 LED’s are on 3 different circuits (for the series video). Why couldn’t you spin 3 (or more) threads of motor coil wire together (which is coated in insulator) with patches of exposed wire to make the circuit? Note that the wire used is silver, and quite thick (like solid core).
I vote custom made wire containing 3 insulated cores. Very clever stuff. Bravo.
Possible, but I think it’s unlikely since you see the soldering being done – that would be some incredibly deft soldering if he’s actually connecting three separate wire and avoiding shorting them.
Ok, go slap together 3 TINY conductors like you say, then try to solder each one individually one handed while they wag around on a table and see if you can get a connection as easily as he did on all 3.
I suspect each LED secretly has a band pass filter soldered underneath it. They switches are changing the frequency of the circuit causing the correct LED to light up. It still baffles me that all three can light up, unless each switch can make a narrow band of spectrum corresponding to each LED.
One of my favorite answers, you could combine all the frequencies into one wave and have all of the lights light up.
Hm, guys, note that LEDs are glowing a little at 2:04, when he touches wire… Or am I wrong?
You are correct it does glow slightly
It does…. he briefly shorts the switches when he holds down the (assumed) positive and the LEDs… BUT only the first and the last LED glow not the middle one… if this (standard/typical) series circuit it would light the first two up brighter than the last one… UNLESS the middle one has a higher resistance (or operating voltage)…
Anyways enough of my two sense!
Notice how the movement of the circuit and the movement of the glow from the lights are slightly off… Just some post-processing here. (He’s doing this on green paper… Coincidence? I think not!)
“Green Screening” and “Blue Screening” haven’t been called that in industry for at least the past 4 or 5 years. The current term is “chroma keying”, because you don’t need either a blue or a green background, you just need a solid contrasting color.
That being said, chroma-keying is not easy to do well, especially when you have small finicky things in the scene.
It’s been called “chromakey” since forever. I heard of the term at least 20 years ago. Green / blue screen is just a layman’s term.
I know this is a month old, but…
http://www.youtube.com/watch?v=mzDTZuFJYX4&list=UUNAAxVKWPAbaZiB90_kjDJw&index=1&feature=plcp
The solution! By the same Polish genius. I was going with video-manipulation, myself, but no! It works live. Clever clever dude.
If someone goes out of his way to show you that there is nothing going on then you can probably be sure that something going on.
The most likely answer would be that the LEDs never turn on and it is all post-processing.
Answers:
1st video (series led’s), its a clever video editing trick. He tracks the lets using motion tracking software (not too complex). You can tell at around 2:35 mark. The green background makes it easy to mask the hands when he passes over the leds.
2nd Video same trick as the 1st.
switches contain diodes and have a voltage drop?
What if the battery is actually giving out an AC supply? The parallel circuit would just require a diode in the switch to ground out the unwanted polarity.
AC might also help the series find a solution too, at work so I don’t have time to diagram it all out.
Yes, in case of two diodes using AC source is working solution. But what about three diodes in series?
I figures 2 could operate using a current limiter on the +ve and the other could work on the -ve.
Conductive thread might be small enough to not see on camera, especially if it is threaded through the backdrop.. YS made a good observation with the led on the left glowing at 2:04.
http://amzn.com/B004G4ZG5U
The clue is in the fact there are only two LED’s
The switches are coils (possibly capacitor tuned too), diode rectifier and switch combos.
One LED’s and one of the “switches” are backwards :D
The 9volt does nothing :D
Well that’s the way I would do it :D
Either that or frame by frame video editing as it is clearly not fixed to the table which was my first idea (through holes in the table, unlikely)
I did consider button cells in the switches. But then how to power both at the same time. I suppose an SMD micro could be in there too with a tiny tactile switch but it would be pushing for space? Maybe switches have diodes and the 9volt has been cleaned out and replaced with an ac supply.
Iv got it here is a microprocessor in the 9volt with a small powersupply (a car alarm remote battery or somethig) and mearly resistors in the switches. They are read analog and then the pins are set to output one in one polarity the other in the other polarity. And are using PWM 50% of te time in either direction (:
That would be the easyest way I can think of (:
I would love to know the real answer to how this was done. Could confound even Johnathan Creek :D
I wonder how close my guess is (:
Video Editing is definitely a reasonable way of doing it – modern software does that very easily (tracking the motion of things onscreen, etc).
It would be much more interesting if he does it without video editing though!
my guess is either adobe after affects, or the switches have tiny batteries in them, and the leds are wired so that the current must flow one direction to light one up, and the other direction to light the other. This would only work for the series one, though.
All video trickery is my wager. And has anybody noticed the LEDs never vary in brightness even though they are being powered from a single current limiting resistor?
Agreed
led brightness would vary somewhat if all behind one resistor, the fact is doesn’t vary any in brightnes suggest to me video has been edited.
Having a consistent brightness could also be consistent with the “AC battery” theory as well: Assuming a reasonably wide-band source with a reasonably good amplifier in the battery shell, notch filters in the LEDs and corresponding switches (with reasonably separated center frequencies). Switching one band on or off shouldn’t have too much effect on LEDs set to the other bands.
Wireless switches and wireless LED’s?
Both circuit configurations apply voltages to all of the components (if they aren’t normal switches). Each switch creates a wireless link to one of the LED’s
Do this with GREEN LEDs on GREEN paper and then I’ll take more than 2 minutes to think of how you did it.
REMEMBER NIKOLA TESLA GUYS!!!
He was a great man (:
who led an interesting life even as a child (:
I would love to have met him (:
R is an L
An old version of the series circuit has 2 light bulbs and 2 switches, all in series. Plug it into 120vac. Like this setup, each switch independently control one light bulb!
The trick in that case is a hidden diode across each switch, and each bulb. Turning on one switch shorts its diode, supplying halfwave AC. The corresponding bulb whose diode is reverse-biased lights. The other switch and bulb have their diodes reversed, so they operate on the other half cycle.
So, this trick circuit might have a DC-to-AC converter hidden in the battery (555 timer etc.) so it produces 9vac, not 9vdc. That would make it easy to control 2 LEDs with 2 switches (and hidden diodes). But I’m not sure how he’d add the 3rd switch and LED.
Probably a One-wire signaling variant.
Addressable LEDs.
Switches are not just switches, but rather, signaling devices which turn on/off their associated LED.
Do they make 5mm addressable LEDs?
If not, is there enough space inside one for a DIY project?
Reminds of minecraft and the redstone switches.
I cannot believe this got into HaD. This circuit is probably legit, but the schematic in the background not. Author of the video is a troll and deletes comments. It was already confirmed that switches are modified and there’s some kind of AC generator within one of these, nothing hard for electronics engineer.
Clue at 2:05
The 2nd circuit is easy as previous commenters point out:
The supply is AC (little microcontroller inside).
The LED’s are opposite ways round. Each switch has an inline SMT diode, such that each switch “shorts” one LED.
The first circuit is harder. Karls solution works for 2 LED’s, but not 3. Here is my proposed answer:
The switches are decoys. All are always closed. Each LED has a SMT inductor and capacitor behind it (in parallel). Each one has a unique “tuned frequency”. The battery has a microcontroller in it, which produces an output which is the sum of signals of frequencies which activate each LED. The user has practised the timing of the video such that flicking the switches match up with the timing in the micro controller program.
Obviously, it could all be computer trickery, but I have a feeling that’s not the case considering the studenty laughing the background as if he is demoing it to a live audience at the same time.
I think you are right in most of your theory but instead of doing the camera trick, you can have capacitor-coil-whatever inside each switch configured to have a high impedance for the appropiate frequency when not bypassed so that the current on that frequency is low and the corresponding led does not emit.
Only thing I can think of is that the switches are not switches but frequency generators, and that each LED has a tiny tuned filter circuit and are wired in reverse bias with an anti-parallel surface mount diode to keep the DC flowing. Not sure how all that would be so small as to not be shown on the video.
Guys there is no Adobe effects!
TIP from author:
“Don’t look at my schematic! Consider, how I can control this LEDs ? Tip: do you know any AC current properties ?”
He said as well that switches are modified a bit.
Most of guys guess well about two LED’s. Quite easy.
Author said that it took him 10 years to find how to switch 3rd LED.
Have ask author to reveal us his secret. ;-)
Forgot to mention that battery is not modified as per author comment on youtube.
Pure video trickery, these circuits CAN NOT work the way the videos show. This is great use of a simple after effects technique. fun videos nonetheless.
