A DSLR Shutter Cable For Android
Here’s a very easy way to trigger your DSLR camera using an Android device. It’s a similar method used with IR triggered cameras, in that all you need to do is assemble some simple hardware to plug into the headphone jack. The app that triggers the camera simply plays back a well crafted audio file to do so. The thing that this cable adds is the ability to use the focus feature, since the cable has two data lines.
The hardware is dead-simple. A pair of NPN transistors and a pair of resistors are hosted by this small chunk of strip board. The audio jack for Android uses left and right audio channels to drive the base of these transistors. On the camera side of things the transistors are pulling the focus, and shutter contacts to ground. Once this is covered with shrink tubing it’ll be pretty rugged, and ready to be thrown in your camera bag for use on short notice.
[Thanks Hannes]
4 thoughts on “A DSLR Shutter Cable For Android
  1. Yea don’t through-hole the wires, wouldn’t want them to be secure. O_o
    Also, I feel like the perfboard could be half the size.
    1. Honestly, I rather the cable break instead of my phone or camera being damaged.
      That said, it would be better if they used smd transistors and resistors. No price difference, and the soldering size would be no different either.
  2. If it’s a Canon camera, typically Magic Lantern or CHDK will do a fine job. But for the inbetween Canons, or other brands, this does a fine job.
Leave a Reply to nizonCancel reply
