A few months ago, we saw a hack where a $20 USB TV tuner was transformed into a software-defined radio capable of reading GPS signals, listening to radio transmissions between aircraft and a control tower, and even a simple FM radio. This project is a perfect introduction to the RTL-SDR and Ham radio scene, but getting these projects up and running can be a bit overwhelming for anyone who hasn’t played around with this before. [Balint] is tackling this problem head on with a series of YouTube tutorials to get SDR noobs up and running with GNU Radio and the Realtec USB TV tuner.
To demonstrate the power of software-defined radio, [Balint] is using GNU Radio and the USB TV tuner that started it all, the Ezcap EZTV668 (conveniently back in stock at DealExtreme, but other options exist). Because software-defined radio is a touch confusing for a beginner to wrap their head around, [Balint] is beginning his tutorial series by explaining radio sources, sinks, and the GNU Radio interface.
Already, [Balint] has put up 5 tutorials and made the flowgraph files available in his gr-baz project. He’s doing a wonderful job opening up the software-defined radio scene to beginners, but he’s still looking for some feedback. If you have a suggestion on what [Balint] should cover next, leave a note in the YouTube comments and we’re sure [Balint] will get around to that eventually.
Outstanding! I have some devices I can test on.
Way to go Balint!
My DX EZcaps were on backorder since the last thread here, but finally arrived last week. :D I did get some “wide FM” local stations working, but for interesting stuff I need a better (discone?) antenna.
I am looking forward to watching these vids when I get some spare time. Thanks! :)
Are these devices easier to find in stock anywhere reliable now? I looked around last time it was discussed and nobody had any.
Had a nightmare experience once with Dealextreme and won’t buy from them again.
i purchased one from ebay and i got it working last night. http://www.ebay.com/itm/160786708241
These were the instructions i finally used to get it working on my win7 machine,
http://www.rtlsdr.com/2012/04/getting-started-with-rtl-sdr-dongle/
and used this hint…
“RTL tuner=e4000 vid=0x0BDA pid=0x2838 readlen=8192”
I made a 2m slimjim antenna and that helped allot.
http://www.hamuniverse.com/2metercopperslimjim.html
I ordered on 30th, and received on the 7th…
To get wideband FM working reasonably well, I had to use a big input buffer (readlen=20K or so in the hint…)
Mine works perfectly. Need a good project for it now though.
Can you by chance use these to tune local Police here in US?
I dont see why not
In short: No.
Reason? Easy they used trunked radio systems. Normal police scanners will not work. However, theoretically you can pick up the encoded signal from the radios and decode them. But this is some hardcore coding and hacking involved, simply not worth the effort since its essentially the same as gsm hacking (works basicly like a gsm device) so they same rainbow tables will need to be generated and used and what what. Rather keep yourself busy with more constructive stuff…
Most emergency services moved over to trunked radio systems. So no fire station, police station, etc.
A lot of police are using APCO25. And some are using encryption as well, like my city is. I haven’t been able to find any projects about people trying to decrypt it. It would be interesting to find. I miss the old scanner days.
I’ve been burned before relying on dealextreme claiming something was in stock when it really wasn’t.
I still buy from them occasionally because of their prices and selection; just keep it in mind.
The thing to keep in mind is that DX doesn’t stock the vast majority of items, they are simply a reseller. Once you buy something from them, they place the order with the supplier, receive it, package it, then ship it to you. This process can easily take a few months, though most orders ship within 1 month.
An item being “In Stock” on DX simply means it exists and they know where to get it. The only exception to this is the items which they keep in their US and European warehouses, but those are a select few high-volume items.
Do they repack? Drop shipping would be much quicker, resellers who don’t even bother take your money and buy it from a 3rd party and have them send it to you.
Becoming popular on ebay. bastards.
I guess that (ordering delays with DX) depends of the stuff ordered. I placed my last order on Friday night and it shipped on Monday. However, it was mostly consumer stuff that they probably have plenty in supply.
Hey all, I can confirm that this tuner works with the software. I’ve been using it specifically with the ExtIO_USRP software package and it works really well. Plus the tuner is in stock and only $10.
Also, for those that don’t like waiting about a month for DX to deliver might find FocalPrice to be faster in shipping. It typically takes them half the time to ship and I always get FP shipments before DX when ordering at the same time.
I received this tuner from Dealextreme today. Its chip is labeled IT9135FN, which isn’t compatible according to the compatibility list I found.
Which tuner does yours have?
Oy, looks like DX strikes again. The tuner I have looks exactly like the one they list in the pics, which I bought in June but the chipset is RTL2832U with the e4000 tuner.
Sorry to hear that you got the other one. Sounds like they just use the same shell with different tuners.
Michal, thanks for confirming we received different versions from DX. The tuner I got looks just like the one in DX’s pictures too.
I tried my tuner today, but as expected, RTL-SDR reported it found no supported devices. No big deal, I’ll go ahead and order one advertised to have the RTL2832.
Any success using rtl2832 and similar dongles under Linux with kernel 3.2+? Modules sources didn’t compile for me; tried newer ones which compiled fine, but failed to create the necessary devices.
I’d like to make a headless networked remote receiver under Linux, but this forces me to use Windows.
Do you mean to view DVB-T or to use as a radio tuner? You don’t need any kernel module to make the dongles work. The userland librtlsdr compiles cleanly on modern systems. I simply compiled the code here: https://github.com/keenerd/rtl-sdr
The great SDR# application is good for beginners and casual users alike for Windows and Linux.
Have a look at http://rtlsdr.org/start and look in the Windows and Linux software links on getting started.
I’ve been waiting for this for a while! VERY EXCITED!
I will have to keep tabs on this.
There also some very active groups on irc.freenode.
##rtlsdr
#sdrsharp
