High Speed Photography Controller Built To Catch Water Droplets
One high-speed photography controller to rule them all. If you’re looking to photograph droplets of water splashing on a still reservoir this is the ticket. But if you’re not, it still offers an incredible amount of flexibility for other high-speed needs. Inside you’ll find an Arduino Mega, which has plenty of room to bend to your will.
[Michael Ross] is the man behind this box. He wanted a system that did it all; timings, droplet control, camera shutter, etc. What you can’t see in the image above is the interface panel on the back of this enclosure (this shot shows the top of the box). The video after the break will give you a look at the overall setup. It has ports to control two different light sources, detectors to snap the images using an infrared sensor or via sound (we’re thinking bullet photography), and four ports to control solenoid valves.
He produced a mammoth PDF tutorial which will guide even the biggest noob through the entire build process. Find it at his site linked above.
6 thoughts on “High Speed Photography Controller Built To Catch Water Droplets
Leave a Reply to MrX Cancel reply
