Nook Simple Touch As A Glider Computer
Look at the beautiful screen on that Nook Simple Touch. It has a lot of advantages over other hardware when used as a glider computer running the open source XCSoar software. The contrast of the display is excellent when compared to an LCD or AOMLED. That’s quite important as gliding through the wild blue yonder often includes intense sunlight. The display is also larger than many of the Android devices that have been used for this purpose. There are a few drawbacks though. One is that unlike other Android devices, this doesn’t have a GPS module built into it. But the price point makes up for the fact that you need to source an external module yourself.
This isn’t the first time we’ve seen the device used as a navigational display. This other hack put a simple touch on a sailboat for the same direct-sunlight-readability reason. For $100, and with the ability to root the system for use as an Android device, we expect to see this to keep popping up all over the place as a simple interface for a multitude of projects.
After the break you can see a video comparing the software running on a Nook display to one on a Dell Streak 5 LCD tablet.
[Thanks Folken]
13 thoughts on “Nook Simple Touch As A Glider Computer
  1. Sorry, dumb question – what is the refresh rate of e-ink and how does that affect its life span? I assume that as a nav aid some of the details would need to update every few seconds at least. Is that a problem?
    If not, then this is SWEET – I’d gladly take a high contrast e-ink that is only black & white over low contrast color any day for a GPS screen.
    1. AFAIK…
      Full screen refreshes take the most amount of time (full blackout, then write), but that doesn’t need to be done often. For something like a moving icon on a map, you can update only that region. It leaves behind some dirty “trails” that eventually need to be refreshed away, in the meantime it’s fast and “good enough.”
      1. Oh wow.. I just watched the video. Did you? That thing works beautifully. e-ink seems to have progressed since I last looked at it.
        1. It has, and the readabiilty of the display in full sunlight has gotten better. When your doing daytime flying, glare is almost no issue.
  2. Finally a replacement for those old and buggy Ipaq 3900 which had one of the best sunlight readable displays.
    I’m pretty sure i’ll build that into one of our gliders. Almost all gliders in germany have FLARM which is a good source for GPS, positions of others in range with that device can be displayd with their height and climbrate.
    Open source navigation software for gliders are now better than any software which you have to pay for.
    thank you for sharing this
    1. This is what surprises me. With so many hacks popping up using these displays BECAUSE they are better in sunny conditions, why aren’t commercial solutions available using them? There are even COLOR e-ink displays now.
  3. http://www.eink.com/sell_sheets/pearl%20sell%20sheet.pdf
    datasheet of eink, not sure if its the same as the one in the nook but it shows a 50k hours as lifespan, that in combination with the 1Hz refresh as seen on the nook has impressed me. Low power consumption, excellent in the sun visibility, good lifespan and more than acceptable refresh rate for most applications… wish I saw this vid sooner.
    Thanks for sharing this :)
  4. Hi all,
    I know tophat project but I guess tophat is a fork going to an easier interface.
    I know top hat born by XCSoar, is it the only “way” to run XCsoar in nook (or any other eink device) or there is one further XCSoar version to run on eink?
    I’d like to run real XCSoar (not a different one, like top hat is). Is it possible?
Leave a Reply to ehud42Cancel reply
